Setting a Personal Security Code (PIN)
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal
Identification Number (PIN) code (01-99).
To select a PIN, perform the following steps:
1) With the phone in standby, press [menu/clock] twice.
The system announces "Security code," and the current PIN code is announced as it is displayed on the base.
Then the system announces the instructions for setting the PIN code.
2) Press [volume/select/ ] or [volume/select/ ] until the desired number appears.
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code"
followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press
menu again."
Note: The PIN code is set to "80" at the factory.
