SOURCE: watch battery replacement
I have a Timex Expedition Indigo with a metal case. Not sure of the exact model number but on the back there an M6 below Expedition. Anyway, I had the same problem of snapping the back back on. I found a "battery" website that had some suggestions that should be typical of any snap back case watch. http://www.online-batteries.co.uk/whichbattery.shtml specifically they said that when you try to press the back on it must be flat (not one edge down as I had been trying) Put the watch face down on a non scratch surface and press with both thumbs evenly. If that doesn't work a press will be needed. If you have a vice a couple of blocks of wood to distribute the load on the front and back may work, otherwise take it to a jeweler with the proper equipment. The thumb routine didn't work for me. I have a vice but figured many wouldn't so I tried something else first. I put the watch face down on a piece of wood. I found a small 2" long scrap of wood (3/4" x 1.5" approx) that spanned the back. I centered the back (aligned properly) placed the block of wood squarely and centered across the back and tapped the end of the block with a hammer. First try didn't work, second one did. I used a rubber mallet as the hammer but a regular hammer or other heavy object would work. The trick, I think, is to get everything lined up and square so the blow is centered and even. Also, I'd suggest cleaning the back and the groove in the case and be sure the rubber gasket is properly positioned. This will give you the best chance of retaining the waterproofing. And remember to check that the watch is running before you do this. Some need to be reset (usually with a very small screwdriver or pin) after replacing the battery. There should be a small hole with some printing next to it. You may need a magnifying glass to see/read it. Good Luck, Richard
SOURCE: Replaced battery, now no beep.
I have a Timex Digital Heart Rate Monitor 585 (product code T5C351F5)m, which has the same Short AC Pad and battery +ve message. There is an arrowhead pointing to the pad. It's a raised metal platform - a bit different to some of the Ironman's mentioned above. Here is a pic...
SOURCE: timex expedition indiglo wr 50m
I had the same problem, and could not find any answers on timex.com. After you place the battery in and it begins to beep, push all four buttons in at the same time. This should "reset" the watch -- at least it did for me.
SOURCE: Timex Expedition sports watch - how to view lap times?
I ran into the same problem w/ my new Timex Expedition. I emailed their help desk and they said that the Expedition models do not have lap memory feature. You need an IronMan watch to get lap recall. Wish I knew that before getting this Expedition watch...
Brian
SOURCE: REMOVE BACK COVER
If caseback is without grooves, it is snap on caseback and you have to insert openers blade under the lip and pry up. Lip is the tiny gap between the case and caseback.
If you have groves in caseback, it is screwdown caseback and you will need special opening tool. Insert the blades in to the grooves and unscrew the caseback.
You can find this tool on eBay.
Rate, please.
