Washing Machines Logo
k
kirankings Posted on Jan 09, 2017
In ifb top load washing mechine it gives e2 error code
My IFB washing machine top load showing Hi error codes, what is the problem?
Try unplugging from the outlet, wait a couple minutes before plugging it back. If problem persists, refer to your manual how to fix the problem. YouTube have answers too.
How can solve e2 error ifb top loading machine aw6501wb
It appears IFB has store branded appliances, and the AW6501WB is manufactured by Bosch.
There is a Service bulletin on that issue:
https://www.bosch-climate.us/files/201109161635590.TWH-G2-35_E2_error_code_troubleshooting.pdf
Sir E4 code open help me ifb aw60-8061
There is no matter with this error code. Just switch OFF the device and switch it ON only after 48 hours. It will reset itself. If the error code is E2, there is no need to make it right. It has gone. Buy an other one.
1helpful
2answers
My lg washing mechine error code EP
Write your answer...my lg top load washer displayed EP or E2 error codes and washer is not working
1helpful
2answers
IFB washing machine front load Showing ' Lo' what
In IFB Machine LO Error Code indicates Low Voltage Problem. We have the best quality Automatic Voltage Stabilizers. Gelco Automatic Voltage Stabilizer GA400 model will solve your problem. GA400 Voltage Stabilizer to up or down your incoming Voltage from GEB. It has a capacity of 12 amp and 15 to 20 Voltage up / down capacity.
We are sure this Gelco GA 400 model will solve your problem.
You can Call on: 9722658052 or 9427347880
Thank You
Top IFB Washing Machines Experts
ADMIN Andrew
ADMIN Andrew
Aron
Are you an IFB Washing Machine Expert? Answer questions, earn points and help others
