You can recover WhatsApp messages from iPhone here with Joyoshare iPhone Data Recovery if you unluckily lost or deleted them from iPhone: https://www.joyoshare.com/recover-ios-data/recover-deleted-whatsapp-messages-on-iphone.html
OPTION 1: Restore WhatsApp Messages Locally
Step 1: The very first solution to your problem is to restore it locally by UNINSTALLING the WhatsApp Application on your device.
Step 2: REINSTALL it again.
Step 3: SIGN IN YOUR ACCOUNT in the newly installed application. Then, you will be prompted with a message that says, you are able to restore your backup after reinstalling the application on your device.
Step 4: All you need is to press RESTORE and your problem will be gone. But you need to keep in mind that the backup for your WhatsApp history is only valid for 7 days and after a week, it will be gone and you will not be able to locally solve the problem.
OPTION 2: Retrieving Deleted WhatsApp Messages by A Data Recovery Software
Step 1: CONNECT YOUR MOBILE TO YOUR COMPUTER WITH A USB CABLE
Step 2: ENABLE USB DEBUGGING THROUGH SETTING UP YOUR MOBILE PHONE
Step 3: Choose the mode according to the operating system. Like this: android 2.3 or earlier, enter SETTINGS and click APPLICATIONS then click DEVELOPMENT and tick USB DEBUGGING
Step 4: Next step that you should take is: SCAN AND ANALYZE THE DATA ON YOUR MOBILE.
Step 5: Lastly, you have to TAKE A LOOK AND RECOVER FILES FROM WHATSAPP HISTORY.
OPTION 3: Use FoneDog - Android Data Recovery to Recover Deleted WhatsApp Messages
Step 1: Download and Install
Step 2: Select File Type
Step 3: Select Mode
Step 4: Select Files of WhatsApp Messages from Android to recover
Video Guide: How to Recover Deleted WhatsApp Messages From Android Phones
More refer:
How to Recover Deleted WhatsApp Messages on Android
How to Restore Deleted WhatsApp Messages on iPhone
You can check whether have a backup file on iTunes or iCloud. It is very easy to restore notes from iTunes/iCloud backup. Or you can try with some special and reliable app. I got to know one, seems to be MyFone Back iPhone Data Recovery, hope it will be helpful. 4 Methods to Recover Deleted WhatsApp Messages on iPhone
More and more Apple users tend to take WhatsApp as their communication tool. If you have been constantly texting with your friends and families via WhatsApp, you must concern much about that WhatsApp data means a lot to you. Possibly, you could back up your iPhone via iTunes or iCloud for fear that important files may get lost unexpectedly. If your WhatsApp messages disappeared one day without a reason, you can follow this tutorial which includes two ways to get them back.
Part 1: Extract WhatsApp Messages from iTunes Backup
If you made backup of your WhatsApp conversations via iTunes previously, you can easily retrieve them by restoring your iPhone. It is an easy job but this operation will definitely erase all the current data on your iPhone. Here we will show you how to extract WhatsApp messages, photos, videos, call log, etc from iTunes backup individually.
Yolisoft iPhone Backup Extractor is a professional tool that can help you view the details in your iTunes backup file intuitively. Then you can export the needed data from the backup selectively. iTunes backup files created for iPhone 7, 7 Plus, 6S, 6S Plus, 6, 6 Plus, SE, 5S, 4S are all supported.
Part 2: Restore WhatsApp Chat History from iCloud Backup
Except iTunes, some Apple users prefer to use the built-in iCloud backup feature. It only takes a few steps to restore the WhatsApp. Yet, before everything gets started, please make sure there is an iCloud backup available in WhatsApp Settings > Chats > Chat Backup. Next uninstall WhatsApp from your iDevice and reinstall it from App Store. Then you can restore the WhatsApp chat history by following the on screen prompts after verifying phone number.
Tips: If you unfortunately haven't made any backup of your data, you can go here to learn how to recover deleted WhatsApp messages
For Android Phones, There are two solutions to recover whatsApp messages.
OPTION 2: Use FoneDog - Android Data Recovery to Recover Deleted WhatsApp Messages
Step 3: Select Mode
Step 4: Select Files to Recover
More information you can see: How to Recover Deleted WhatsApp Messages on Android
What kind of phone do you have? If you're on an iPhone and have previously backed it up using iTunes or iCloud, you may be able to retrieve deleted WhatsApp chats by restoring your iPhone from backup.
From iCloud Backup
To recover your chat history from an iCloud backup, first verify that an iCloud backup exists in WhatsApp Settings > Chats > Chat Backup. If you can see when the last backup was performed, delete and reinstall the app from the App Store. After verifying your phone number, follow the on-screen prompts to restore your chat history. The same iCloud backup requirements apply for iCloud restore. In addition, the phone number used for backing up and restoring must be the same. You cannot restore the chat history from another WhatsApp account. If you share an iCloud account, this will allow you to keep your backups separate.
From iTunes Backup
1. Open iTunes. First go to Edit > Settings > Devices to disable automatic syncing.
2. Connect your iPhone to computer. Wait for a while, right-click your iPhone in the devices list and click "Restore from Backup".
3. Stay in the backup file contains WhatsApp messages, click "Restore".
If you don't have backup at all, try this iPhone WhatsApp message recovery program on your computer. It's able to recover WhatsApp messages directly on your computer.
http://www.leawo.org/tutorial/how-to-retrieve-whatsapp-messages-on-iphone.html
There is an article Guide: How to Recover Deleted WhatsApp Messages on Android
