SOURCE: Simpletech 250GB not working with my computer
This is the email I sent to & received back from the company re: the same problem I was having with it. You don't need any drivers.
PROBLEM: I have followed directions re: plugging device in, still cannot see device in MY COMPUTER. I have also tried plugging both USB's into computer to no avail. Even tried using it on my laptop, still not showing. My desktop is XP & loaptop is Vista. When I go to remove the dirve, it DOES show as Fujitsu, but I cannot acces the drive or locate it elsewhere. I really want to like this, but will have to return it if this issue is not resolvable.
SOLUTION: You might need to initialize the drive.
Right click on “My Computer” or “Computer” on Vista.
Select “Manage”
On the next screen select “Disk Management”
In the lower middle section you should be able to find your drive.
It will show up as Disk 1 or Disk 2….depending on how many drives you have in your computer.
If you click on the area that says Disk # you should get and option to “initialize drive”.
Also to the right it should show the allocation information for the drive. If it says “unallocated” then the drive needs to be partitioned.
Right click on the white box next to the drive listing.
Select the option “New Partition”
This will bring up the partition wizard and you will need to step through this process.
Select a primary partition.
On the next screen accept the maximum size it will provide.
On the next screen you assign a drive letter.
On the next screen you will do the format and accept the default settings.
The formatting will start and will be busy until it is complete.
You can monitor this from the disk management window.
Regards,
SimpleTech Technical Support
SOURCE: I am using windows 7 & I have m2n mx asus
Since Windows 7 is not officially released yet. There are no dedicated hardware drivers for this version of windows. If your hardware is Vista compatible, try to select the vista drivers for your sound card and it should work
SOURCE: Mikomi DC-7130 webcam worked on windows xp but
You could try using a Vista driver, most of the time they'll work in Win 7.
Let us know if that works.
SOURCE: Trying to install Labtec drivers for my labtec
You can contact Labtech from here
http://www.labtec.com/index.cfm/service/splash/AMR/EN,CRID=3
You may have to run it in Compatibility mode if Windows 7 webcam software is not available - I'm sure they can advise you
To navigate to CM on my logitech I rightclick the webcam shortcut icon on the desktop and click 'Properties' and then the 'Compatibility' tab.
SOURCE: Windows 7 driver update for Belkin F5D9050
Im Not sure this will Work
But in most Cases it will So I think its Worth a try
You will need to find the version of the Adapter
And After that Goto www.belkin.com/support
On the top right hand side on the search type F5D9050
On the results select the Link that has the Drivers
Download the Driver for the version of your Adapter
Right click on the downloaded file and select Properties
Click on the compatibility tab
Select Run this Program in compatibility mode for Windows Vista SP1
Click Apply
Now install the Drivers
Testimonial: "It´s working fine now, thanks!"
