2-3" long, lots of star wheels and spacers
SOURCE: delta 23-880 bench grinder
You should be able to hold the grinding wheel with a pair of leather gloves on your hands and lossen the bolt. Look very carefully at the threads to make sure you are trying to lossen and not tighten. Some are left handed threads on bench grinders.
SOURCE: older black & decker bench grinder
Usually a new wire wheel comes with different size bushing just for the problem you are describing. Either that or take it back and get one specifically for your tool.
SOURCE: replace front wheel bearings
hi emelinabarne
the link below is the parts catalogue for your bike. page 47 and 48 includes an EXPLODED view of the front wheel assembly. actually of all the parts.
http://www.yamaha-motor.com.mx/Manual_Partes/Catalogos/Deportivas%20(Crucero)/XVS1100%20V%20Star/5YS8_2005.PDF
hope this helps you out buddy.
regards,
voodoo
SOURCE: Grinder settings for Vienna Deluxe
Hi
To start off with, you should not change the big knob unless the grinder is operating at the time.
Set the small knob to the middle position. You can move this any time. Move towards the + mark to strengthen the coffee, but never all the way to the full +.
Set the big knob to the #8 to start off with. Move it 1 # smaller to make the coffee stronger but be careful not to get it to fine as you will clog the grinder and you will have to take it apart to clean. If you ever get an out of beans light, but there are beans in the hopper, open the knob to #16 for 1 cycle, then turn it back down to a # 1 larger than you had before and leave it unless you get the message again. Shiny beans call for a coarser grind than a dull bean because of the oils in the coffee bean. Oils will cause the grinds to stick together and cause clogs faster than beans that have less oil.
SOURCE: bench grinder, 110/220?? wired up properly
LIKELY the capacitor which is usually in the base is bad.
The capacitor shifts the phase angle in one of the two windings which creates a pseudo rotating field to start rotation.
