SOURCE: lakewood 7096 heater
Some of the newer models have a thermal fuse which may be blown. It doesn't look like a normal fuse at all. It is similar to a transistor in looks and should have continuity from one end to the other. It will be tied in to the incoming power cord inside the heater, and may be covered with rubber coating within the wire. It will look different when you notice it. Sometimes its too far down inside where the heat causes it to blow prematurely. The purpose is to cut the power to the unit in case it overheats. You can get one at radio shack for less than a couple of bucks. The older models don't normally have one, but I would suggest you put one in it if that's the case.
SOURCE: I need the switch for Lakewood 7096 oil heater
This might be the switch,
Defond DRH-2415 15A 125VAC Lighted Dual Heater Switch
SOURCE: lakewood radiator 5500 heater scehmatic
visit this webpage for service center and parts: http://www.lakewoodeng.com/html/parts.html
SOURCE: ROCKER SWITCH DIAGRAM
On the top of the switch (inside the heater) there is a common connection.....even though it looks as if it is connected (electrically), it isn't electrically affected by the switch; it's just used as a post. It's just the place where the striped wire connects to the "common" point for the heater coils (they are in a parallel). Also, while you're in there you might want to put some electrical grease on the exposed conductors.....mine had quite a bit of corrosion (which was the reason for the failure). I had to replace 3 of the female connectors.
SOURCE: Lakewood Model 7101 - Need to drain the oil to dispose of it
I just drill a hole and I put old oil in my used motor oil
