Televison & Video Logo
Bemjamin Shively Posted on Jan 06, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My proscan plded3992a-c is flickering - Proscan Televison & Video
Level 3:
Top Expert:
  • Proscan Master 76,851 Answers
  • Posted on Jan 06, 2017
Proscan Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15003360
Points
237762
Flickering can be adjusted. To some rare cases, the SMPS [Power] board might need replacement. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
2 Related Answers
gopakumarg43
  • 76851 Answers
  • Posted on Mar 23, 2015
SOURCE: Proscan LCD flat panal model #plded3992a-c. Hello. I turn monitor on, blue screen is dim and blinks. Will not hold picture. Power? Or bad card?
Bad card. Electro help
gopakumarg43
  • 76851 Answers
  • Posted on Aug 16, 2016
SOURCE: I have a Proscan plded3992a . When the TV cuts on you can see and hear everything, currently via hdmi. The screen however is dim. Still visible and blinks steadily to normal brightness.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
My Proscan turns on , sound is good .I see only a flicker of the picture in the dark room ? what can i do ?
If it was my TV I'd recycle it then buy a name brand set, Proscan sets are plagued with issues.
My proscan tv 39 inch PLDED3992A WILL NOT POWER ON AT ALL IS THERE A RESET BUTTON.
Try plugging the TV into another known good outlet. If there is no change unplug the TV for 30 minutes to 1 hour. Plug it in and try to turn the TV on again. If you have the same result, you have a bad main board that needs to be replaced. If its under warranty have it repaired or exchanged. If your warranty has expired take it to your local TV repair shop. Hope this helps.
I have 39 inch proscan model plded3996a and the picture is flicker everything else work fine
Flicker to picture can be adjusted. To some sets, you have to adjust it at its main power supply regulator section [there will be flicker adjustment preset]; and to some others, you have to enter its service mode option to adjust this. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the phrase 'Flicker adjustment' or "Flicker" in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Pc hdmi no sound
some televisions require a seperate audio feed from the HDMI cable to hook up audio. if you have the cables for this i would try that first. normally ends up having to go thru an AV connection
2helpful
I need a remote code for Proscan PLDED3992A to use with Xfinity Cable
There's now way the ir files could get from Comcast into your remote. Without a upload. So yes.
Proscan tv flickering
My proscan did this. I took off the back. Spotted the buldged capacitor. Went to Fry's to find a replacement. They didn't have one but they referred me to someone down the street. Called, he had it. Cost like 2 bucks. Got a soldering kit for 15 bucks. Removed and replaced. And it's like brand new again! 4 years later, the main board is going out :/ that's not so cheap.
Top Proscan Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
