SOURCE: voicemail number (Tracfone)
try dialing: 1 and then send. The number does not have to be stored in your phone book as it is usually part of the pre-loaded software
SOURCE: cell phone silence
This problem seems to be related to the contacts list - makes no sense but in my Son's Env phone if he removes one of his contacts it fixes it! it seems that it only happens when someone in your contact list calls or you call them. Weird...then it will happen again and same thing fixes it.
SOURCE: RAZR V3 voicemail problem
press the envelope then highlight the voicemail push the menu key wich is the line key above the circle in the center of the phone either putin your number or call the company and get the voicemail phone number for the area that you are living in.
SOURCE: voicemail password
call your provider and ask for it and they'll give it to you.. gud luck man
SOURCE: voicemail doesn't work
I would check with your cellular provider to make sure that they kept your voicemail when you purchased the new phone.
