Hardware & Accessories Logo
J
Jane Haan Posted on Jan 04, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Setting time to go on and time to go off on a brinks model no. 44-1060 timer
John mullen
Level 3:
Master:
  • Master 296 Answers
  • Posted on Jan 04, 2017
John mullen
Master
Level 3:
Master:
Answers
296
Questions
0
Helped
75974
Points
1130
Somebody asked the same question six years ago: Do not know how to set the brinks 44 1060 timer
Need instructions for setting up brinks timer model number 42-1034
Copy following link for setting analog timers by experimenting with features.
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/Woods-timers-and-manuals.html#Brinks
Add a comment and describe product in detail
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Lost manual for model 44-1020 need help setting it
1) Copy following link for possible Brinks timer manuals:
2) Add comment and describe timer in detail for possible identification.
3) Buy another timer from Walmart, with instructions, and return defect timer in new box.
6helpful
Setting the timer on the Brinks timer model # 42-1006
The way to set it is two-fold:
1. pull out the tabs for the times you do not want the light (or other) to be on. The tabs that are left in will be powered.
2. Set the time of day by turning the know to the indicator arrow.
1helpful
Help me work this thing please?
Brinks analog plug-in-outlet timer??
Copy following link for instructions how to set timer by experimenting with features:
2helpful
I have the brinks timer model 42-1009 can you tell me how to program it
Copy following link for setting timer:
3helpful
Need how to use my timer. Brinks digital plug in home timer. Model # 44-1020. 6 settings per day. Battery backup
Manual appears on following links:
http://waterheatertimer.org/pdf/Brinks-44-1020-manual.pdf
The manual has important illustrations, and has more words than allowed for free answer.
Open manual and get as far along as you can, and then add a comment where manual is confusing and I will help.
The battery is rechargeable type, so plug timer into outlet for hour and then unplug timer to set programming.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
4helpful
2answers
Please assist me in setting this light timer. brinks-42-1020
Instructions for Brinks 42-1020
1) There are plastic segments located around outer edge of timer dial.
These segments divide each hour into 15 minute periods.
Push segments down like a piano key for all hours you want timer ON-or-OFF
2) Push switch to Auto ON -or- Timer
3) Turn lamp ON, make sure bulb is working, plug lamp into timer.
4) Plug timer into wall.
Manually rotate timer dial clockwise to observe light turning on-off.
This action will say if light is ON when segments are up or down.
5) Unplug timer, and set segments for times you want lamp to turn on-off.
6) Rotate timer dial clockwise until current time lines up with arrowhead located on inner dial
7) Plug timer back into outlet. Dial rotates as time passes, segments click a switch that turns lamp on-and-off.
Add a comment for more free help, or to further clarify this free answer.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Top Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
