Washing machines kick off when they're out of balance, like if something is too heavy and waterlogged on one side. Redistribute the laundry and it will be fine.
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
if agitates an does not spin means is not going to drain, cause for not spinning broken door switch, look an see if you can feel it hanging or loose, if the swtich is broken it will not go into spin mode at all...........door switch is a safety device!
It sound like you drain hose is siphoning off the rinse water, It needs a standpipe make sure the drain hose is at about the height of the top of the washer, Make sure the drain hose isnt stuck in the drain it also needs an air cap. the drain hose should not lay on the floor to run to the drain
Please let me know if this doesnt solve your problems
