How do i refill a hp 920xl office jet cartridge. its out of a 6500 printer. i cant find anything on the internet.
To refill 920:
1. If you have the plastic cap that covers the 9 mm. hole where you can see the sponge, then tape this cap to the cartidge with scotch tape. If not, use some duct/masking tape to cover the round hole.
2. Use the dry hypodermic needle to find the hole that will be found at the very center of the 920 label. With the needle, pierce the label.
3. Fill the hypodermic needle with 4 cc of ink.
4. Insert the needle 2-3 cm. into the hole made in step 2. Draw out 1 cc of air, then slowly force the 4 cc of ink into the sponge. Use toilet tissue to absorb any ink that might have escaped.
5. Let the catridge stand overnight (if possible) so as to allow the ink to evenly saturate the sponge. If not, insert it into your printer immediately.
Note: If you are going to refill catridges, be certain not to allow the sponge to dry completely. Thus, you might want to do step one immediately and to enclose it in a sealed sandwich bag upon removing an empty catridge from your printer even if you are not going to fill it immediately.
I have posted a youtube video showing how to refill the HP920 cartridge. The method I have devised is brand new and works - really works. Check it out here:
If my advice helps you like nothing else you've tried before,
then consider sending me a small donation for the time&effort i put
into devising this simple solution - Donate via paypal to
[email protected]
click here to jump securely to paypal:
https://www.paypal.com/cgi-bin/webscr...
Regarding "meleskanos" "solution" that is really a question asking if it is true that when one refills an HP 920 ink cartridge for a HP 6500 printer if there is a computer chip that prevents it from working I can say this: Absolutely NOT. At least not for the black HP 920 cartridge in my Hp Officejet 6500 Wireless. I just refilled my cartridge according to the #1 solution given by "moderator" and it worked fine. My print level indicator for the cartridge still shows low but its still printing fine.
Regarding the "Clarification Request", I have been using the same ink I was using to refill my old HP Officejet G85xi cartridges without a problem.
There is also an option in the printer to turn off the ink monitoring feature:
On the printer control panel press the setup button, then select preferences, then select cartridge chip info, and press 1 to turn off the ink gauge.
I did this yesterday but now after I select "Preferences", no option is available for "Cartridge Chip Info". Maybe when you turn it off it doesn't give an option to turn it back on again? Crazy, but I have no option any more under "Preferences" for "Cartridge Chip Info".
I followed your directions and it worked for me. And The same thing happened afterward: The option to turn Cartridge Chip Info back on again has disappeared...
Don't buy the refill kit or cartrige hp920xl from 123refill.com. it does not work, I tried it. And when I called them, no help at all, got disconnected and when I tried to call back (10X) NO ONE would answer my phone call. BAD BAD BAD, that is all I can say about 123refill.com
I used the drill method in the video. Took a while to get it printing again but so far, so good. THe low ink light went out so the pritner thinks the cartridge ink level went up as it did.
Will post again if it breaks.
Dr Bill
Meleskanos, may well be true, I successfully refilled the other 3 cartridges, and these printed ok, but the black ran out shortly afterward. I refilled the black 920, but the 6500 will not print the black. The printer is displaying that there is a problem with the cartridge. I have shut down/started up the printer 2x now. Once started back up, it recognizes the black cartridge ok, but still will not print black.
I used the hole the guy in the video didnt want to mess with. I pushed it in using a nail punch. It filled quite easily and then covered it with a piece of tape.
I had the same problem with my HP 6500 printer.I refilled the black 920 through the middle hole under the label, be patient it will fill. It printed fine and the printer actually reset the level indicator to full. I later refilled all 3 color 920's after the printer showed they were empty. I figured it was worth a shot. Well, I went crazy it wouldn't print any colors and the printer showed they were still empty. I went into the troubleshooting sortware from HP and followed the instructions to auto clean the printer head and then the cartridges. Guess what, it began to print colors. The indicator still shows low but who gives s**t it works now.
The information you got meleskanos is probably more in the way of HP uses a proprietary chip that doesn't allow for "clone" refillable ink cartridges but does allow HP to sue companies that attempt to copy the specs. of it's cartridges. You can successfully refill an original HP cartridge because it contains that chip.
BTW- you can buy "clone" refillable ink cartridges, but the consumer must transfer the HP chip to the clone cartridge. Those cartridges allow, apparently, a greater volume and an easy refill access port. They're "made to be refilled". I have no experience with those cartridges as I think the chip transfer part would be a pain in the arse. Way to go HP, you won that battle!!!
I'll be damn ... I too have had this same exact problem with the black only. ALL other colors have been refilled successfully. For the life of me can't figure out why? Maybe Meleskanos is right after all. After re-reading his post he does state BLACK cartridge. But why wouldn't HP block the other colors also?
This works and is easy. no drilling or other nonsense or buying continuous ink systems.
http://www.ehow.com/how_7408694_refill-hp-920-cartridge-ink.html
and turn off the ink monitoring on the printer that reads the chips. its a useless monitor anyhow. this means the printer can still print even if you refill it.you can do it on the menu panel on the front of the printer.
I am using a continuous feed ink system with my 6500. There are also replacement cartridges as described by PirateMorgan. You do have to move the chip from existing cartridges to the new ones, but it's a one-time thing (though it took me an hour to get the chip positioned right due to the vendor template being wrong). The printer reports I'm out of ink, but it doesn't interfere with my printing at all, and my ink costs have gone down beyond my satisfaction.
A refill company here in Israel said that the black HP 920 cartridge that comes with the new HP 6500 has a computer chip that will not allow the cartridge to work after being refilled. Is this known to be true?
the kicker here is that HP wants you to use OEM products period- there is a huge lawsuit out now about these printers giving false low ink readings so you will be duped into buying more of their overpriced cartridges. You CANNOT change the chips after refill but your printer will always show low ink-heres the key, DO NOT refill any cartridges that say empty as the chip will NOT allow printing for that color! hard to gauge whats really low or out but once it shows OUT on the printer its time to get ripped off w OEM carts. :^( thought you'd like to know....
EvilHPdom is exactly what I am thinking. I refilled all 4 of my 920 cartridges. they all worked fine except the Magenta! Why, why .... Ahhhh the magenta was empty, all the others were low.
I believe the answer is refill before the printer marks the chip empty. Once the chip is marked empty, it will not allow ink from that cartridge.
I think the people above, had their black cartridges marked empty, this is why they will not print.
Regarding your question about HP 920 ink refilling, please note that all Costco USA (all stores), Costco Canada/Mexico/UK (most stores), Fry's Electronics USA (all stores), Best Buy Canada (13 stores) support this ink cartridge series. Our network of retailers stand behind the product and performance - guaranteed. For store locations and details on ink refill pricing:
Costco USA Ink Refill Service (465+ stores):http://www.costcoinkjetrefill.com
Costco Canada Ink Refill Service (59 stores): http://www.ca.costcoinkjetrefill.com
Costco Mexico Ink Refill Service (35 stores): http://es.costcoinkjetrefill.com/
Costco United Kingdom (7 stores): http://uk.costcoinkjetrefill.com/
Fry's Electronics Ink Refill Service (34 stores): http://www.frys.com/ads/page51
Best Buy Canada (13 stores): www.geeksquad.ca/inkrefill/
We also have ink refilling centers in many University stores across the USA & Canada, including:
Brigham Young University, Brigham Young University - Idaho, Cornell University, New York University, Queen's University, San Diego State University, University of Calgary, University of San Diego, University of Virginia and University of Wisconsin - Madison
Refill Store Map Locator: http://www.go2ris.com/
Just bring your ink cartridges into any of our authorized refill center locations. The in-store representatives (at either Photo/Electronics support center) are trained to refill over 270 different ink cartridge types from all the major manufacturers (i.e. HP, Epson, Canon, Lexmark and Dell) and can answer any additional questions you may have. It typically takes less than an hour to complete the refill from the time you drop the cartridges off. Our network of retailers stand behind the product and performance - guaranteed. All of our inks are Made in America and closely match original manufacturer's ink quality - we are sure you'll be satisfied with both color 'pop' and image longevity performance.
The RIS InkCenter - the power behind retail Inkjet Cartridge Refill Services: http://www.youtube.com/watch?v=e7tlmEexor8
Save Money. Save The Environment.
Customers who have questions regarding the use of refilled ink cartridges can visithttp://www.inkjet411.comor contact us directly at [email protected]
Alternatively, if a refill center is not close to you and you need to purchase a new ink cartridge(s) and are trying to cut costs, we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating, come with a 1-year warranty and provide free shipping for all orders above $20 (available for US Residents only).
-Thank you
SOURCE: hp 6500 office jet refill
to refill 920:
www.catherinecollege.net
Is the actual ink any different than most common re-fill inks used for HP?? I have some ink I used for my old HP932. Will it work in my newer HP6500?
