Cars & Trucks Logo
J
James shanks Posted on Jan 04, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2006 Chevy express 2500 instrument panel lights stopped working after two wires touched going to tow switch. No blown fuses
Jeff Armer
Level 3:
  • Cars & Trucks Master 15,575 Answers
  • Posted on Jan 04, 2017
Jeff Armer
Level 3:
Answers
15575
Questions
Helped
7100406
Points
73899
Which I/P lights ? Instrument cluster , radio , HVAC control panel etc.... All the I/P light's are controlled by the BCM - body control module . Do you know about electronic control modules ?
DTC B2610 Passenger Compartment Dimming 1 Circuit
The body control module (BCM) receives a variable voltage signal from the instrument panel (I/P) dimmer switch requesting to illuminate the instrument panel controls illumination lamps to a desired intensity. When this occurs, the BCM directly sends a variable voltage based on the I/P dimmer switch position on the backlight lamps control circuit, instrument panel lamps dimming control circuit, and the LED dimming signal circuit.
Voltage for the backlight lamps control circuit, instrument panel lamps dimming control circuit, and the LED dimming signal circuits is from the TBC 3 fuse 16 in the underhood fuse block directly through the BCM to these circuits.
• Perform a visual inspection for loose or poor connections at all related components. Refer to Testing for Intermittent Conditions and Poor Connections in Wiring Systems.
• A short to ground in the following circuits will cause the TBC 3 fuse to open:
- The backlight lamps control
- The instrument panel lamps dimming control
- The LED dimming signal
- Battery positive voltage from the underhood fuse block TBC 3 fuse
• An open in the TBC 3 fuse will cause the BCM to set the following DTC:
- B0951
- B2610
- B2625
DTC B2615 Passenger Compartment Dimming 2 Circuit
DTC B2620 Display Dimming Pulse Width Modulation (PWM) Input Circuit
DTC B2625 Display Dimming Pulse Width Modulation (PWM) Output Circuit
Do you know how to Test for a high resistance, an open, a short to ground, or a short to voltage in the following circuits. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
• 5-volt reference
• The dimming input
• The dimming return
Tow/Haul mode enables the operator to achieve enhanced shift performance when towing or hauling a load. When tow/haul mode is selected, the tow/haul switch input signal to the body control module (BCM) is momentarily toggled to zero volts. This signals the powertrain control module (PCM) or transmission control module (TCM) to extend the length of time between upshifts and increase transmission line pressure. Cycling the tow/haul switch again disables tow/haul mode and returns the transmission to a normal shift pattern.
After reading all the pertinent info. to your problem, doing testing ,Checking for DTC'S -diagnostic trouble codes in the BCM , checking power and ground's for the BCM an checking voltage at the tow / haul switch to and from the BCM .is where i would start . Do you know how to do electrical testing ? Read a wire diagram ? If not there are videos on youtube for learning how to do basic automotive electrical testing , how to read wiring diagrams etc... You can find free wiring diagrams at
http://www.bbbind.com/free_tsb.html The only thing with this is you don't have info. saying where componet location's are . This is were factory service info would be helpful
1helpful
2answers
Body control module location 2008 Chevy express 2500
Body Control Module (BCM) is located in the
Lower right side of the instrument panel behind the knee bolster !
Where is the fuse for cigarette light plug on 2006 chevy 2500 express van
The fuse should be tuked up under the dash on the drivers side fuse panel. marked cig or pw+
No brake, turn signal, or flashers at rear of 2006 chevy express 2500
Sounds like a bad turn signal switch. I bet if you wiggle the turn signal lever while you have your foot on the brake pedal the left and right brake lights ill intermittently work.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
I have a 2002 Chevy Avalanche 2500 with dash lights out. Not only did these lights go out but the power locks also stopped working at about the same time. Not sure if that is coincidence or what. All the...
Factory repair manual step by step testing procedure for Interior Backlighting Inoperative. In your course of testing let me know if you need location for anything .
Turn ON the parklamps.
Ensure the panel dimmer switch is at maximum illumination.
Do the illumination lamps operate normally?
YES - Go to Testing for Electrical Intermittents in Wiring Systems
NO - Go to Step 3
Is only one lamp inoperative?
YES - Go to Step 4
NO - Go to Step 6
Test the instrument panel lamp supply voltage circuit of the inoperative lamp for high resistance or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
YES - Go to Step 17
NO - Go to Step 5
5
Test the ground circuit of the inoperative lamp for high resistance or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 17
NO - Go to Step 11
6
Do the park lamps function properly?
YES - Go to Step 7
NO - Go to Park Lamps Inoperative
7
Inspect the ILLUM fuse.
Is the fuse open?
YES - Go to Step 12
NO - Go to Step 8
8
Connect a test lamp between the ILLUM fuse and ground.
Does the test lamp illuminate?
YES - Go to Step 14
NO - Go to Step 9
9
without disconnecting the switch, connect a test lamp between the instrument panel lamps dimmer switch signal circuit at the headlamp and panel dimmer switch and ground.
YES - Go to Step 13
NO - Go to Step 10
10
Inspect for poor connections at the harness connector of the headlamp and panel dimmer switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
YES - Go to Step 17
NO - Go to Step 16
11
Inspect for poor connections at the harness connector of the inoperative bulb. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
YES - Go to Step 17
NO - Go to Step 15
12
Repair the short to ground in the instrument panel lamp supply voltage circuit. Refer to Wiring Repairs in Wiring Systems.
Replace the fuse.
YES - Did you complete the repair?
NO - Go to Step 17
13
Repair the open in the instrument panel lamps dimmer switch signal circuit between the switch and the fuse. Refer to Wiring Repairs in Wiring Systems.
Go to Step 17
14
Repair the open in the instrument panel lamp supply voltage circuit. Refer to Wiring Repairs in Wiring Systems.
Go to Step 17
15
Replace the inoperative bulb.
Did you complete the replacement?
Go to Step 17
16
Replace the headlamp and panel dimmer switch. Refer to Headlamp Switch Replacement .
Go to Step 17
17
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 3
3helpful
2answers
Fuse Box Diagram needed for 2006 Chevy Express 2500 Van
i own a 2006 chevy express cutaway box truck the interior box lights are not working and i do not know what fuse designates them can any one help me locate the proper fuse
2answers
Headlight won't come on
The headlights have 2 fuses. One is a main power feed under the hood in the distrabution box and the other is under the dashboard. Check the fuses and then check for power at the switch. If you have power at the switch then its not a fuse its the switch and the trailer you had connected most likely shorted and back fed into the parking and dash light circuit. Those circuits also run from the light switch.
2helpful
Chevy cavalier temp guage stopped working on instrument panel
if the wiring is good and there are no blown fuses, likely the gauge itself will have to be replaced
1helpful
2006 Chevrolet Silverado 2500HD tail lights stopped working
I am having the same problem on an 04 2500hd there isa 15 amp stop light fuse inside the cab on the side of the instrument panel and a 25 amp stop light fuse under hood. you could also have a break switch issue the switch is located up on the break pedal linkage you should have power on the white wire when you push the pedal in (check with a test light) in my case I have a broken wire along the frame rail in the harness it is a light blue wire,
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
