Hello Irene Booth,
There are several things you can do to check the suitability of your freezer settings ... (eg: if you put a small container of water in the freezer...
Is it mostly frozen in about 45 minutes??
Things that would aid in trouble shooting...
Liebherr nomenclature: model number...???
New... or new to you?
Had previously worked... Never worked.
General observations... Frost forming in back of freezer area
Doors square and fitting properly...
Gasket in full contact (visibly) all the way around the freezer door/drawer... and is in good condition
- (can physically check by pulling a dollar around the gasket).
If the Ice Maker has EVER worked ... We can skip the basics of checking the water supply is hooked up and TURNED ON.
If you can fit your fingers in the ice tray to feel for water or ice in
the tray ... that would also be helpful.
Finally... for new models... check that all packing tape & materials around the ice-maker have been remove.
Although your model appears to be a TWIST TRAY type of ice-maker... there is still a sweep or fill bar that is supposed to check the fill level of your ice bin.
A single chip of ice can hold that from moving freely... your ice maker will not work ... !!
Hope this helps
Carnac the Magnificent
