It is hard to understand exactly what you want to do. Here is a link to the product support site for this item. You can download all the manuals and software updates. You may also want to review the FAQs section. http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=us&ctn=42PF7421D/37
First, you need to make sure all of the vent panels on the tv are clear of obstructions. Heating may be causing the problems. Next, get a hold of a clean, dry source of forced air and blow out the inside of the case and the internals of the tv.
The problem with your TV is the screen tabs this is where the electronics bond to the screen a technician may be able to fix it with compression pads otherwise it a new screen
Try another hdmi wire. Physically look at the hdmi port and see if there is damage done to the port. Change the source. IE another cable box, xbox 360 dvd play etc. If all else fails, change SSB or Scaler. Depending on the set. It'll be one or the other. I don't have my information with me at the moment to distinguish which one you'll have.
I know on the plasma TV's it was a matter of updating or downloading and re-installing the firmware/software for the TV to fix the issue. Go to the following page and if the model you have is indeed a 42PF7421D/37 download the software on the page. Make sure you follow the installation instructions to update the software otherwise the set will become a 150 lb paper weight.
I had the same problem when we hooked up an hd satellite box. It's a simple solution using the Philips remote that came with your tv. The dial in the center of the remote with up down left right control will move the picture left or right up or down by holding the direction you want to go. Make sure to stand in front of tv.
Green Screen with some lines
lines are called retrace lines.
it is due to
maybe dry soldered or no green drive signal. This problem can be fixed by complete soldering in crt board.
1 green video supply absent
2 loose contact in green skt in crt board
3 crt board loose
4 no green drive signal.
