F19 is an error relating to heating, hence clearing a blockage did nothing, theres a good chance the heating element is dead you will need a multimetre to test it
E21 is a circ pump blockage issue. Check that all hoses are clear, unit drains completely. Depending on the age, a new circulating pump may be needed or new motor capacitor.
Error codes are cryptic but usually indicate the obvious. Probably drain pipe blocked with junk build up. Clear blockage. Spring curtain rod up the pipe. Ouch....
Perhaps a little draino.
Error code F-19 means "Lower oven is not heating".
The manual suggests:
"Press UPPER CLEAR/OFF or
LOWER CLEAR/OFF to clear the display
and stop beeping. Reprogram oven. If fault
reoccurs, record fault number. Press UPPER
CLEAR/OFF or LOWER CLEAR/OFF and
contact a qualified service technician."
You can reset the error code by the follow steps. Turn the knob to the off or reset position, 12 o'clock. Turn the knob to the 6 o'clock position. Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position. Continue holding the spin button for about 5 seconds then release the spin button and now turn the knob to off When your turn it back on it should have cleared the error code.
