If any of the troubleshooting steps listed below solve the problem, attempt to verify printer functionality (instructions listed below). If functionality is verified, no additional parts should be replaced.
NOTE: Always verify the printer's current Firmware release and upgrade as needed.
CAUTION: Never replace both the Ink Supply Station and the Electronics module at the same time. The printers Model ID will be lost.
SOURCE: "System Error" has occurred when the power is on.
same problem....what is the fix? - asap PLZ. In advance, thx
SOURCE: BONJOUR MONSIEUR :JAI DES PROBLEMES AVEC MON IMPRIMANTE HP500PS
MY DESIGNJET 500 HAVE THE 79:04 ERROR IT WAS JUST CUTTING THE PAPER WHEN THIS OCURR
SOURCE: HP 500ps showing error is System error 86:01
System Error: 86:01
Problem Description: Carriage-Axis shutdown.
If this error code appeared but was NOT caused by a paper jam, then try the following:
* Too much friction in the Slider Rod. lubricate the Slider Rod.
* The Carriage is bumping into the Service Station. If the carriage
is stuck at the right hand side of the Printer and cannot be moved
out to the center of the Print Platen it is because the Service
Station cannot uncap the Printheads. In this case replace the
Service Station/Aerosol Fan Assembly
If you need more help come back.Post /
thumbs / testimonial are
welcome!
