USING THE MODE BUTTON SAY TO SET THE TEMP AT 22
Greeting Cyril Hrachovy,
"Say" 22 is an example... You should input whatever temperature where you are comfortable ...
Our master bed room has it's own controls... but usually the vents have been blocked shut... or have magnetic diverters (plastic shields) on the vents... where the thermostat is all warm & happy across the room while I'm freezing against the glass...
A happy medium has to be struck
- between the IVORY-TOWER instruction writer... and
the sun soaked rain drenched REAL WORLD in which
we live (I'm just saying).
Programmable THERMOSTATS are get (fun)... but in reality
the automatic features are soon abandoned... (harmony)
and the REMOTE favors the fickle.
Carnac the Magnificent
Free Haier Air Conditioner User Manuals ' ManualsOnline ...
homeappliance.manualsonline.com > ... > Household Appliance Haier
Products 1 - 50 of 548 - Haier Split Type Room Air Conditioner Operation Manual. Pages: 0 Saves: 0 ... Haier Room Air Conditioner Installation Manual. Pages: 0
From
the main menu choose "Parental Controls;" it's option six.
Choose
the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK
button on the remote, scroll through until the TV-MA rating appears. Press the
right arrow button to move the highlight over to the "Status" field
and toggle to "View." Press the OK button. This will set the
age-based ratings to Mature.
From
the Parental Controls menu, select the second option, V-Chip Movie Ratings
Limit and change the rating to TV_MA and the "Status" to
"View."
From
the Parental Controls menu select the third option, V-Chip Unrated Program
Block and select item one, which will be "View."
Select
the fourth option, which is "Channel Block." Highlight the Channel
field and using the channel up and down buttons, go through and check they are
all set to 'View." Any set to "Block" will need to be toggled
back to View.
Lock the controls to activate the changes using item six on the "Parental Controls" menu.
SETTING THE TIME AND DATE ON
AN OLD 4 BUTTON DIGITAL WATCH
[L1] [R1]
[L2] [R2]
SETTING THE TIME.
Press [L2] to move through
the modes. When the time display flashes, you are in the correct mode to set
the time. The hours first, then the
minutes and seconds.
Press [R1] to advance the
numbers, [R2] to go to the next.
Press [L2] to save your
settings. [L1] is not used; it's the light.
SETTING THE DATE AND DAY. After setting the time (seconds flashing)
push [R2] to move though time, backwards, to date, [R1] to set day, [R2] to
move to month [R1] to set the month. Push
[R2] to get to the day of the week, then [R1] to change. [L2] to end.
