SOURCE: need wiring schematics for goodman
Here is a diagram containing the Wiring Schematics for Goodman Gas Furnace
SOURCE: goodman gas furnace power vent motor and housing replacement
You need to type GOODMAN GAS APPLIANCES into you browser to find you local servicecenter. I must tell you that Goodman only sells to authorized service companies in my experience. So you become EgKraft Company.
SOURCE: goodman furnace leaking water
Yes you can use regular pvc glue. You should use pvc primer before you glue it.
SOURCE: Goodman Furnace
Could be that the fan on you new furnace is more powerful than your old one and is forcefully blowing the cold duct air out causing a temporary chill or it could be that you need to adjust the fan delay.
I'm not familar with this unit so I wouldn't have aclue on how to do this or even if you can.
SOURCE: Goodman GMP100-5 Rev Furnace Manual
Hi I have a Goodman Furnace GMP 100-5 with an AC connected to it. How should the wireing be connected to the furnace. It does not work when we turn on the heat. Currently the furnace has a brown wire coming out with 5 wires which is connected to the brown wire from the AC unit. The furnace also has a yellow, white, brown, and green wire hanging out. The thermostate brown wire has 5 wires and the yellow wire is connected to the red wire on the AC wiring and the red wire is connected to the brown furnace red, the green wire is connected to the green wire coming out of the furnace. The other 2 wires white and blue are not connected to anthing.What is the proper way this should be wired?
