Question about American Standard Home
Serial no. 6495853 model no. 7236L020
This is for Ana American Standard Whirlpool tub and I am looking for replacement parts
6ya staff
SOURCE:
arealplumber
Better Plumbing
  • 33 Answers
SOURCE: american standard whirlpool tub #2425
Here is the link to installation instructions:
American Standard #2425
The information you need is on page #7.
Hope this helps!
Posted on Dec 05, 2008
Anonymous
  • 7 Answers
SOURCE: Whirlpool pump only buzzes.
Well there are two things....You say "buzzes?" Like pump is running "humming" & not pushing water. That would be an "airlock" in the pump & it needs to be primed.
If it's "buzzing" & pump motor is not turning (Like it's froze) you might have a bad start up capacitor on the pump that needs to be replaced. Worst case scenerio entire pump needs replacement.
Posted on Jan 14, 2009
Anonymous
  • 125 Answers
SOURCE: I bought American Standard whirlpool
no manual. Sounds like the motor is no good. What model and brand of pump do you have?
replacement Bath Pumps
Posted on Feb 24, 2009
Fred
  • 62 Answers
SOURCE: We have an American Standard lifetime whirlpool
Chances are that the drain assembly was not part of the tub but a 'generic' plumbing part. Is this pop up drain the type that you push down and it clicks closed and push down and then it pops up? It unscrews from the drain fitting and you can get a replacement at a big box store. A better pop up replacement is one called a Rapid-fit. It drains faster.
Posted on Jun 05, 2009
bwbconstruct
  • 23 Answers
SOURCE: Button on American Standard Whirlpool tub is stuck
most tub buttons are attatched to a small air tube thats connected to a switch. if that tube came off the button wont work. just look inside your access panel the tube will be there check both ends if one came off vut 1/4 inch off and reattach
Posted on Jul 20, 2009
Have an American standard whirlpool tub. the on/off button is stuck on on. now the only way to shut the jets off is to flip the breaker to the bathroom. how do I fix this
This sounds like the air switch in the motor is not working properly. You will need to remove the pump from under the tub to access the air switch located in a housing on the motor.
Replacement Air Switch will cost you about $20
US Parts Center
Aug 27, 2013 | American Standard Home
We have an American Standard whirlpool tub. It's probably about 20 years old and we haven't been able to find the model name or number. It's about 4' by 5'. Our problem: we don't...
you have to access the lower control the switch should be an air type one it uses air pressure from pushing in the button they some times crack ,dislodge or damaged and will not turn on or off unit also switch can fail
Jul 12, 2017 | American Standard Cambridge 5 Ft. x 32"...
My American Standard Whirlpool does not turn on. I push the Power button and don't hear anything. Circuit breaker is on, anyone have any ideas? Thanks!
Remove access panel make sure pump is plugged in some electricians put a GFI outlet under tub for motor make sure GFI did not trip. Next the switch is an air switch look for the hose going to switch is connected last you may need a new air switch which is common to fail
Nov 03, 2009 | American Standard 2770.018w.020 Cadet...
My American Standard whirlpool pump will only hum.
The bearings (or bushings) of the pump or pump motor have siezed, these can be replaced on some models but for the most part you will need to replace the pump and/or pump motor. and as where to get parts, i would suggest the outlet from wich you purchased the unit or another appliance outlet. Or if you feel up to the challenge, im sure you could find replacement parts on the internet: google, ebay, etc.
Sep 29, 2009 | American Standard 2770.018w.020 Cadet...
We have an American Standard lifetime whirlpool tub with the pop up drain (white). However, the pop up drain plug has always been tempermental but now it no longer wants to stay down.
May 12, 2009 | American Standard Evolution 1599.205.020...
Home Logo
57 people viewed this question
Top American Standard Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
