Question about Samsung Televison & Video
Can I use a power board from US Samsung tv in Asia TV? The part number of the two is exactly the same? However, the voltage in US is 110V and the voltage in Asia is 220V.
The US Samsung TV is UN32EH5300F series and Asia TV is UN32EH5300J series. The power board is with the same no. BN44 00493A. Your expert advice please.
    Top Expert:
  • Samsung Master
  • 66,120 Answers
Ever heard of an adaptor .
Posted on Dec 29, 2016
  • Wilson Lee
    Wilson Lee Dec 30, 2016
    Thank you very much. However, I wish to know if parts with EXACTLY the same part number is what we are looking for in future.
    Master:
  • Samsung Master
  • 362 Answers
Posted on Nov 05, 2019
6ya staff
SOURCE:
Testing power supply for Samsung UN40H5203 TV
If you have no power at all out of the power supply board, then either the incoming fuse is blown or the power supply board is toast. Part of the board has to be powered all the time waiting for a signal from the on button from the TV or remote. Remember check for AC and DC voltages at the appropriate places because if you check with the wrong setting on your multimeter you'll get 0 volts.
BE CAREFUL WITH THIS BOARD AS THERE ARE HAZARDOUS VOLTAGES EVEN WHEN THE TV IS UNPLUGGED!!!! (and even if it's not working! The capacitors can hold a high voltage charge for weeks!)
Sep 08, 2016 | Samsung UN40H5203 40 Inch 1080p Smart
My samsung tv is making clicking noises and won't turn on
Clicking noises may mean a power supply voltage is not staying correct or that board is bad---a suggestion: visit shopjimmy.com who has by model number a list of all the boards used in almost every Samsung Flat screen set made.
Jun 17, 2012 | Samsung Televison & Video
Is the Samsung Ln46a530 dual voltage ie (110 America - 240 Europe)
The tv power supply board is not the problems,that can add a transformer to solved it easily.The problems are US and Europe uses a difference tv signal frequencies.The US,Canada and Mexico are using a NTSC signal frequencies.Europe,Asia,Middle East and Africa are using PAL signal frequencies.U must have a tv that call REGIONS free tv to work in Europe and US same time.If u just have a standard LCD or a Plasma HD tv buy it in the US for example will not work in Europe
Jun 09, 2011 | Samsung LN46A530 46 in. LCD HDTV
When you click on the power of our samsung tv, it takes 15 minutes before it actually turn on. what could b e the problem and how do we fix it?
there is problem with your power supply must be filter capacitor fautly.please changed with same number.its look like 220uf/400v or other number.
Oct 18, 2010 | Televison & Video
Samsung TV plugged into the wrong power outlet
maayong buntag dong,,you can do it by your self i teach you how,Open the back cover of your TV.Along with the AC power cord there is a component called varistor this varistor serves a protection for over voltage.Its color is green round shape with two terminal pins just remove it from the board replace the fuse with same rating and your tv will work again..anyway im from bicol albay.
hope i helped you..
please rate my help tnx dong!
Jun 06, 2010 | Televison & Video
110v lcd tv was plugged to 22ov outlet
Hello nik286, hi, check first the label at the back of the TV, look for a voltage input something like a 90V-240V, if you see this, its an autovolt system, this type of power supply input is standard nowadays. Assuming your asking what would be damage, this could be anything from the fuse, thermal resistor, rectifier diodes, and the regulator IC of the power supply board.
Apr 12, 2010 | Sansui 19 in. LCD TV
I have a Samsung HLN617W and am relocating to Germany. I'm thinking that the TV will not work properly since the Germans use the frequency of operation of 50hz and the TV is set to the American Frequency...
No,the main problems USA,European,and Asia are the NTSC or PAL tv signals frequencies.Sometimes the 110 volts or 210 volts,need a tranformer for that to step up or down the voltages for that.The Hez,the tranformers inside the power board convert for that.The colors wheel is dead,it dead!Will not make no diffrent in spinning RPM revolutions of the colors weel.
Apr 02, 2010 | Samsung HLN617W 61" Rear Projection HDTV
42" samsung has sound ,compltely black
I would need the exact model number, but it sounds like you have a bad inverter board. The power supply could be bad and not supplying the voltage to the inverter bord but since you have sound, I doubt that's the problem
Nov 25, 2008 | Samsung Televison & Video
Televison & Video Logo
65 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
