Question about LG Washing Machines
LG front loader WD14071SD6 won't fill and run on cold wash. Works fine on hot. Thanks
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 81 Answers
The main causes your washing machine is not filling with water MAY BE:
1. One of the water valves (hot or cold) supplying the washer with water has been turned off or closed.
2. Your washer has a shutoff valve on the back that may be in the closed position
3. There may be a water filter on your washer that is clogged and tells the washer computer (control board) to not allow water to enter.
4. A hose or water connector on the back or inside the washer is defective or clogged.
Posted on Dec 29, 2016
6ya staff
SOURCE:
I have an lg front loader washing machine that won't fill.I've checked,cleaned the filters. Checked the solenoids,the meter reads I.Are they no good and if so how do you get the parts off the machine.
So it won't fill on a cold wash or a hot wash? Seems odd that both hot and cold valves would go bad at same time. And you know water is turned on I'm sure. Try a rinse/spin cycle and see if that works.
Mar 22, 2018 | LG Washing Machines
My LG front loader is showing an "FE" error. The water seems to continue running into the tub, leaking out the door.
Good morning
I looked this up to make sure I was thinking the right way. The FE means there is too much water in the machine... lol bet you already knew that. Since water is actually coming out of the machine it looks like a bad fill valve. The plastic piece your hot and cold water lines hook into is not shutting off all the way.
I hope this helps
Nov 27, 2012 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have an LC front loader washer that has a water hammer problem when the hot water tries to fill the machine. It works fine with the cold water only. It makes my house pipes bang loudly and it is...
actually its a part that needs to be installed before shutt off valves you can find them at your local plumbing shopp lowes homedepot or menards or call a local plumber
Jan 23, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Never Runs Cold Water LG Model WM0532HW
When set to Cold it Fills Hot ?
What does it rinse with ?
Have you had the fill pipes off the back for some reason and put them back wrong or has a plumber been messing with the supplies
If the machine is told to fill cold it should, it should also use cold water to rinse with.
What hapens if you tell it to fill Hot only
Jun 13, 2009 | LG WM-1832C Front Load Washer
LG WFT653A, water continuosly filling
that solinoid must be conected rong
sean it before
Jan 22, 2009 | LG WD-14124RD Front Load Washer / Dryer
Water is not filling up.
turn off water
disconnect fill hose from tap
examine screen inside hose end for 'muck' blockage
clean screen
reconnect hose
test washer
if no fill
replace water solenoid valve
note: cold water valve fails first, it gets most use,
if only using cold water, you can simply swap the hot and cold hoses at the tap, and swap the hot and cold electrical connectors on the solenoid valves, the hot solenoid is no the cold one and the washer can be used, cold only, for about as long as it has operated thus far..
Oct 14, 2008 | Fisher Paykel EcoSmart GWL15
WASHER WON`T FILL FULLY WITHOUT RE OPENING TOPLID SEVERAL TIMES?
water valve should be a single unit consisting of a hot and cold solinoid assembly. This whole valve assembly should be replaced.
Jul 20, 2008 | Washing Machines
Washing Machines Logo
59 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
