Question about HP LaserJet 3015 All-In-One Printer
I have HP p3015 printer scanner. During scanning, multiple pages are picked up
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,363 Answers
The tires are most likely worn out. to give you more time clean with alcohol.
but will need replacing
Posted on Jan 06, 2017
6ya staff
SOURCE:
How do I scan multiple pages to one file using a deskjet 2512 printer/scanner
On the control panel, select scan to computer and choose PDF.
If you are using the sheet feeder, it will scan all pages and create one file with them all.
OR
If you're using a scanner glass, i.e. one page at a time, when the first page finishes scanning, you will get a message asking if you have another - answer YES and follow the instructions (basically that means place next page on scanner glass and hit OK/Continue). Rinse and repeat until you've scanned all pages then answer NO.
You should find a PDF file in your HP Scan Folder usually named "scan.pdf" unless you've changed the settings. (If there is/are already scanned files in that folder, they will have consecutive numbers, e.g. "scan001.pdf" "scan002.pdf" etc
Sep 25, 2018 | HP DeskJet Office Equipment & Supplies
How do I scan multiple pages with readiris
Google is ALWAYS the first place to check. Just search for scan multiple pages hp readiris
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Jan 02, 2017 | HP Office Equipment & Supplies
I printed several documents and then got a 51.10 error on my HP P3015. It tells me to turn the printer off and on, but this does not resolve the issue.
This error means that the laser scanner assembly has failed. That you are able to print a couple of pages is a pretty common symptom. Eventually it will fail entirely, so time to replace it. Part Number should be RM1-6322-000.
Aug 26, 2014 | HP P3015 Laser Printer
Scan multiple pages pdf
1, Double-click on the printer icon on your Desktop and select the Scan a Document or Photo option from it. Lift the Scanner lid and place the first page with scan side facing down.
2, Check the scan settings and click Scan document to file. Click the Scan button, and the scan process will begin. Now remove the first page and replace the second page on the scanner glass. Click on the "+" sign located at the left-hand side of the display.
3, In the same way, continue scanning other pages too. Once you completed scanning all the pages, click Done after saving the file with a file name.
4, You can change the destination name in the printer settings. In this way, multiple pages can be scanned as PDF.
For more printer related queries get in touch with our experts by just giving a call @ 1-866-293-9220
Jan 31, 2014 | HP LaserJet M1005 Printer
HP Laserjet M1522NF MFP Scanner adf
Please try to use scanner glass and see the resultSecondly try to scaan to PDF for multiple files.If the issue still persists clean the rollers on the ADF and if not working, replace the ADF
Apr 20, 2012 | HP LaserJet M1522nf Multifunction Printer...
How to scan multiple pages in one pdf in hp 5300c scanner
To do this will take a few steps.
1. You need to install a PDF printer driver on your computerfirst. There are quite a few freeware PDF writer programs on the Internet youcan download one such as CutePDF.
To download Cutepdf PDF printer driver (freeware) click onthis link :- http://www.cutepdf.com/
2. Scan the first page then click on File - Save the image as a jpg file Eg. image1.jpg
4. Repeat step 3 for the other pages.
5. Close the scanner when finished scanning.
6. Open a Word document then place each image file on a new page in the Word document
7. Save the Word document (not necessary).
8. Click on File - Print then select CutePDF printer (or your PDF printer driver) and save the PDF file. This PDF file will contain the multiple pages of the scanned pages.
Jul 07, 2011 | HP ScanJet 5300C Flatbed Scanner
Do not know how to scan multiple pages on the HP 6110 all in one Office jet. Please advise, Thank you, Andres
Hi
Click right mouse on the scanner icon and then change the file setting of your scanned file. Change it to pdf file not jpeg to scan in multiple pages. Another is by changing pdf to jpeg using the printer itself. Use the LCD screen menu to navigate.
Another way if you can install ADOBE ACROBAT READER PRO SOFTWARE, you can scan with multiple pages. Regads
Jun 21, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Scanning Multiple pages into one pdf
Scanning a multi-page document as a .pdf file reverts the settings for rotation, selected area, etc. to default for any pages after the first page. This applies to Mac OSX 10.3, 10.4, & 10.5. A simple, but tedious work-around is to scan each page as a separate file and easily recombine them using OSX Preview. Just open the first page, view the Sidebar, and drag-drop the additional page files into the sidebar. Save and it's all one multi-page .pdf.
Jun 26, 2009 | HP Photosmart C5280 Printer
Scan multiple page documents
On my scanner, I feed the documents on the ADF feeder (paper feeder) and when it finishes one scan, I tell it to continue. It will scan all you docs and put it in on file that you can send as one attachment.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 26, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP LaserJet 3015 All-In-One Printer Logo
113 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
