SOURCE: my brother MFC-665CW printer has
plz try by uninstalling your printer and reinstall the printer
SOURCE: Ink Absorber Box
If you lift the scanner and then carfully remove the cover that is on the same side as the ink cartridges the box should bein the back and you can remove it and clean it and let it dry for a while then reinstall it. if you need more help just do a live chat request for ME and i will help you
SOURCE: mfc 440cn printer says 'ink empty' to new full ink cartridge
The usual obvious fix is to buy a new catridge, insert, power off
machine, then switch back on to reset any sensors. But if the circuitry
on the machine itself is faulty it wont fix it.
I used to own an MFC 260C. It had a perfectly good full ink
catridge in it, that was working fine, until...it suddenly did not
recognise the cartridge anymore.
I pulled the machine apart and found that 2 of the 4 sensors on the
cct board at the back of the cartridge housing were loose. These
sensors pass light through the exposed part of the cartridge to see if
ink is there. So if these are faulty, you will never clear the "No
Cartridge" or "Ink Empty..." or "Near Empty Ink ..." messages on the
MFC260C and prbably other similar printers in the MFC range.
Why did they fail? Because the soldering on these sensors was poor quality.
I would never buy another Brother machine because of this, also
because they design the machine to be totally useless unless all the ink ccartridges
are full. Shame on you Brother, and kiss my *** for the $160 pile of
junk I bought off you that was only on its second batch of cartridges
(ie very little use)
SOURCE: I'm receiving error message 46
Welcome to Fixya. To fix error 46 on borhter printer please follow the steps below.
1) Enter machine maintenance mode
- FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
- Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Thanks for using Fixya.
SOURCE: how to reset brother j125 printer's ink absorber full
