SOURCE: demo mode
Hi... your radio has 2 power wires. One is red and the other is yellow. Check for power on both of these wires with the key on. If both have power then you probhably have them switched around!! (one is constant power for memory to "remember" the settings, the other is key on power to that the radio knows the ignition key is on or off. From the sounds of what you are describing it sounds to me like you have your wires switched around...
SOURCE: Kenwood KDC-MP635 STUCK IN DEMO MODE
Turn the unit onto standby then press and hold the menu button then scroll down to demo using the toggle switch on the right then press and hold the toggle switch for a few seconds and it will change to demo off. It's not too difficult but you are correct, it doesn't tell you correctly in the installation instructions.
SOURCE: Stuck in demo mode
When you are in STANDBY mode hold the menu button for a few seconds and a special menu should pop up. In this menu you should be able to set the clock, turn off or on the beep, and take your unit out of demo mode. Good luck.
-Andrew Hawkins
SOURCE: Aiwa CDC-X504Mp stuck in demo mode
This recently happened to my Sony, maybe it will help u
If this cd player has a removal fascia then try..
Carefully inspect the the electrical contacts on the fasica and the cd player. If it has got dirt on them then CAREFULLY CAREFULLY clean with cotton swab dabbed in cleaning Alcohol.
SOURCE: radio wont work, stuck in demo mode?
you put something in the blue input thing
that puts the stereo in demo mode
