Attached L&R cables to the Input (REC) connectors on Tape Deck (I hadn't changed these) and other ends to L&R connectors on the Receiver (these had been disconnected). Attached L&R cables to the Output (PLAY) connectors on the Tape Deck (I hadn't changed these) and the other ends to the L&R connectors on the Receiver (these had been disconnected). Plugged Tape Deck in the "Switched" plug in on the Receiver. Turned Receiver on, Turned Speaker switch to "A", Turned Function switch to Aux. I get a power on light on the tape deck. But when I hit "Play" button, I get no movement in tape or sound. Tried two different tapes, and tried turning them around. No Luck. Any ideas? Thanks, Dan
You have to select any available 'tape loop' .
Receiver Tape Out (Rec) - to INPUT
Receiver Tape In (Play) - from OUTPUT 1 or 2
A tape deck would hang off the back of the EQ using ITS tape loop.
