Mitsubishi WS-55513 55" Rear Projection HDTV Logo
Posted on Jul 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No picture on my TV just audio.
The picture comes in and out once in a while. Is this common?
Anonymous
Level 1:
  • Contributor 34 Answers
  • Posted on Jul 23, 2009
Anonymous
Contributor
Level 1:
Answers
34
Questions
0
Helped
15378
Points
72
For a Mitsubishi WS-55513, there is no "lamp" in the technical sense.
  • CRT Projection: Within this category there are three types of CRT Projection. All of which are different ways to combine three colors Red, Blue and Green into one picture. The combining of the colors is called convergence and will need to be calibrated periodically to make it look right.
  • One CRT with three colors on it already
  • A basic lamp with a color wheel that has the three colors on it
  • Three CRTs (sometimes called Color Guns), one of each color
In the case of your particular television, it has one CRT BOARD/SET which has been discontinued by the manufacturer.
dholaday
Level 3:
Master:
Sergeant:
  • Master 226 Answers
  • Posted on Jul 21, 2009
 dholaday
Master
Level 3:
Master:
Sergeant:
Answers
226
Questions
0
Helped
95549
Points
1179
Sounds like the lamp is burnt out
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
How can i fix my ganzklar lcd tv..no picture but it has sound
https://www.youtube.com/watch?v=ysHfaQKI45M
If you've switched on your TV and the sound comes through fine, but you're not seeing any picture; there are 3 potential issues. No video with normal audio on a Smart TV will the result of one of the following issues: A connection issue; the most common problem. ... An issue with the device connected to the TV.
Samsung TV has sound, no picture. Picture just stopped one day. An idea's that could cause this, 3 Brd's Logic, Pwr and T-Con
https://www.samsung.com/au/support/tv-audio-video/my-tv-has-audio-but-no-video/
I have audio but no picture on my Zenith Z50PG10 50" plasma tv?
Plasmas are like tube TV's(CRT). Once the plasma tube breaks, air gets in, plasma gas gets out. And that's it. They are an enclosed vacuum picture tube. I don't know why people buy plasma. The newer LED have a much better picture. Rich people who swear by plasma, are ridiculous in my opinion. Again, if plasma tube breaks, thats it. Any wrong jarring can break a plasma tube.
Chennai free tv audio is not come but picture well displayed
Hello
Check its speaker first. This is a common faut to this free TV. If it is OK, replace the audio output IC. OK.
Samsungh LA40B530 No picture but sound
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync, but if otherwise then
The ysus board is the most common reason.
you can try websites on ebay.com to buy parts for replacement...
The tv picture is coming in shadowy
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Bad color and picture
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2answers
No Audio, picture fine
this is a very common problem just unplug tv for 5 minutes it
should fix it . simple fix most of the time with rca and proscan.
If that does not do it go into menu scroll down to audio and then press on .
thanks doctor video leading edge electronics
2answers
Sony KV-35S66 Audio ok but no Video
Is your picture somewhat weak ? This could be a problem with the picture tube . One thing you can try is to turn the screen control up just alittle at a time to see if the picture comes in . Once it does turn off and back on to see it it comes back on again . It might take 10 to 20 seconds but if it does your picture tube is weak . The control is on the flyback transformer it is the bottom control . Or it may be on the crt board on the picture tube . One thing to check once the picture comes is the video input . If you go to this mode and see faint white lines might want to try to turn the control down a little more to see if you can get them out and the picture stays on , if not thats how going to have to watch it . These picture tubes are expensive $500.00 to 700.00 depending on which one you have . One possible other thing if you tell me the picture was a great picture almost like brand new check the horizontal section for a loose connection as this will cause this problem . Don't get shocked and be carefull , Good luck
1helpful
5answers
Sony KV-36XBR250 - no picture, good sound
This is a common failure mode (which I now share), and has nothing to do with the picture tube or surge protection. From the forums I have searched to-date, it appears to be a failed component in the flyback circuitry, but Sony will not admit to an inherent defect. If anyone has ACTUALLY FIXED this problem, please post a reply. Guessing won't help anyone. Thanks.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
