Question about Samsung Un46eh5000fxza un46eh5000 46 1080p led-lcd tv - 16:9 - hdtv 10
Samsung UN46EH5000F Main Board Replacement & Post Install
Replaced main board, now the HDMI inputs are not recognizing. Wondering if there is a setting in service menu I have to update/change or the replacement board I got was defective.
6ya staff
SOURCE:
Anonymous
SOURCE: le40r88bd hdmi 3 not showing in menu, keeps going
Exact same problem with mine mate, and it died very soon after. It refused to come on and would just 'click' away. TV is 24months old. Luckily I took out the extended warranty and Currys have it just now trying to fix it. Will let you know what they come back with!
Posted on Nov 02, 2009
specialistel
  • 8909 Answers
SOURCE: I have a Samsung LN46C630 that got fried through
I would replace the power supply as they are not too expensive.
New M/board, should be OK. Have you checked the RAM for errors and installed the latest BIOS firmware?
Posted on Dec 06, 2010
lovejoy91
Dehancy Barney
  • 691 Answers
SOURCE: I got a tv donated to our church for bible study
If you have changed these boards you need to first check your Va and Vs voltages, you should see a white paper listing the proper voltages, if you have a way of checking there are TP where you should put meter and get the proper voltage and also pots that you turn to change voltage. Make sure these are there first before continuing Bill.
Posted on Jan 28, 2011
Mas Baz
Basuki Jrobenk
  • 177 Answers
SOURCE: samsung plasma ps42a450 p1mxl x main
hello jsinghjassi,
That panel problem. Because short in panel line. If you see in to right side of panel, you can see spark or fire from inside panel.
You must replace panel. It's expensive. My suggestion better you buy new one.
Posted on Apr 11, 2011
SOURCE: Where to buy a Samsung BN97-00964 main board?
There are several on Ebay, just make sure you go with a Top Rated Seller W/a reasonable return policy.
Posted on Nov 10, 2012
What board controls the input, my input comes up HDMi and the screen stays black as the HDMI disappears.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 29, 2017 | Televison & Video
Hisense 46" or 48", not sure which, will not change input source. currently on HDMI 3 for fiber optics cable but when HDMI 1 or 2 is selected the source won't change, it just stays in HDMI 3.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sep 05, 2016 | Hisense Televison & Video
LG 42LC46 wont show any hdmi input for more than 3 mins
http://electro-medical.blogspot.com/
Feb 16, 2016 | LG Televison & Video
Element eldfw407 has blue screen only does not get menu or input screenswhat would cause this
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 10, 2015 | Element Electronics 40 Class LCD HDTV -...
Lightning Storm messed up one HDMI Input
Nov 09, 2017 | Panasonic VIERA TC-P50ST30 50-Inch 1080p...
After about 1 minute of operation I lose the picture when I change from HDMI 2 to HDMI 1 and then back the picture comes back for 1 minute then it is lost again. I moved the input to HDMI 1 and the same...
Dec 06, 2017 | Philips 63PF9631D 63 in. Plasma Television
The HDMI inputs on my tc-p50x1 will not work at all. Both component inputs work, but all three of the HDMI seem to get no signal. Is there a fuse I can replace, or do I have to replace the entire...
No,the HDMI connections hubs are just a few small components parts that was put on by the wave soldering machine and it is on and surface mounted by soldering fussion to the tv to main tv Tuner signal board and funsction as one board,can't replaces these HDMI hubs by itself,it very hard and almost imposible to do so by hand soldering equipments and these HDMI components hubs they don't sell out as individual consumer parts any way.Tries tv unplug,replug it back like about and hour later for the tv to do a resetting itself back to the factory setting.Than go to the tv menu go to PICTURE setting go down to do a resetting to do a resetting to all the funsctions of the tv Tuner signal board.Now all ur HDMI hubs should be working again.If not,the whole Tv Tuner signal board mut be reolaced.Try website like Ebay.com to buy a whole refurbish main tv Tuner signal board for the replacement.
Apr 07, 2011 | Panasonic TC-P50X1 50 in. Plasma HDTV
The hdmi input # 1 and # 3 do not work, only input # 2 and # 4 work. why?
Either they are turned of in the option menu of the set or the signal/main board has a logic switching problem, or the HDMI jacks themselves are bad. You can take a flash light and look into the jacks to see if any of the pins are bent. If they are, the board that they are soldered to must be replaced. I would double check the option menu for setting up the inputs of the tv. This would be my first guess.
I hope this helps.
Skyassoc
Dec 11, 2010 | Pioneer PDP-4360HD 43 in. Plasma...
Toshiba 40XV645U - No picture on HDMI 1 when TV is turned on
I assume that you have set the input source selction as in Page 32 and HDMI 1 is solid and and not grayed out. If so check the Preferences menu and see if there is an option for power on set up.
Also look at page 51 about HDMI feature settings. I assume you turn the cable box on first before turning the TV on.
Dec 19, 2009 | Computers & Internet
HDMI INPUT HAS FAILED
DId the technicians try to reset the HDMI.
The HDMI module will need to be reset after service
. Enter the service
menu and select “2”, the Self Check option. Power off the unit using the
Remote. Allow the unit to complete its Cool Down cycle, then unplug the AC
Power. Reconnect the AC Power and power on unit. Confirm HDMI input
operation
sorry the font change on me. this unit has compatbilty issue with some hdmi sorces. there is also a safety interlock sensor if it see extra light it thinks your trying to do something wrong and locks up hdmi.
WARNING. Service mode can result in further damage to set. Care should be taken not to mess with settings unless you know what they are.
1) Set to "0 minutes" using the [SLEEP TIMER] key.
(2) Press the [VIDEO STATUS] key and [DISPLAY] key
simultaneously, then enter the SERVICE MODE.
(3) When the Main Menu is displayed, press [2] key to enter
the self check mode.
(4) Turn off the power by pressing the [POWER] key on the
remote control
Nov 17, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Samsung Un46eh5000fxza un46eh5000 46 1080p led-lcd tv - 16:9 - hdtv 10 Logo
132 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
