SOURCE: We have two bizhub 920 setup with different IP
You mean you can only send to one of the BizHubs? Then you have obviously setup one of them wrong? Can you ping it? Ifd you can't then it certainly won't print. Are you sure about the IP address and configuration? Try another cable. The port may even be bad on your router. try swithing to the port that the working machine is plugged into.
SOURCE: i install konica bizhub 350 to my network.
This is what I've used so far for Network printing and work fine.
setup guide (pdf)
SOURCE: konica minolta bizhub pro 920 the ADF unit is not detect the machine
software switch to detect adf is set to not detected ` not sure off the top of my
head but I think 1-4 if set to 0 make it a 1 or vise versa
Hi kaisar , we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
Has it ever worked on pc ?
Have you just connected it now ?
What operating system is the P.C ?
Did you install the printer's driver on the P.C. ?
