Assume you have a rectangular area such as a room and, for example, you want to calculate the square footage area for flooring or carpet. The way to calculate a rectangular area is by measuring the length and width of your area then multiplying those two numbers together to get the area in feet squared (ft2).
John, square footage is L x W = 285 x 90 =25650 sq.ft.
cubic feet = L x W x H = 285 x 90 x 80 =2052000 cu.ft.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
If the system is actually doing everything it can, which I do occasionally run into, then it's time to start looking at other factors like the heat loads. Number one problem I run into is either attic insulation or attic ventilation. One thing that really sticks out in your post though is the square footage and tonnage. Now, to be honest, what the square footage is from the home owner to actual living space always varies. Home owners always get the square footage like a realtor, but includes the garage and other unconditioned rooms. What your looking for is the square footage of only the rooms that have a vent. It is 400cfm per ton, 1 cfm per square foot. So if you have a 2.5 ton system, it is capable of doing 1000 square feet of living space. You said 1500 square feet, which would need a 3.5 to 4 ton system. Hope this helps and gets you to cooler days!
Ash fault? I think you mean "asphalt" but that's OK. You haven't given enough information to solve the problem, but here's what you need to do.
You know the area of the roof is 300 square feet (sq ft). You should know the area of each asphalt shingle, although that's the information you didn't give. When you know that figure, the calculation is very simple:
number of shingles needed = area of roof / area of one shingle
I don't know if this is a class problem, or if you really have a roofing job. Don't forget that on a real roof, the shingles overlap. If you do the calculation, the number you get is right only if you lay the shingles edge-to-edge. A real-world roof would need probably twice that number. Shingles come packed in bundles, and they usually tell you the area they cover. (By the way, 100 square feet is termed a "square".)
