It seems like a spring or something may have broken or come off on the foot pedal. There is no tension resistance when pushing it forwards and it just bottoms out all the way forwards and the tractor does not move.
SOURCE: After stopping, tractor does not engage in forward or reverse
sounds like the by pass rod has been pulled out
SOURCE: JD 855 the idle spring broke and th hydrostatic
Yes there is a safety switch.And this safety switch has to be engaged.If its not engaged then the JD tractor will not start. On JD 855 the safty switch is located under the seat, There is a rod that must be depressed before engage Somehow that rod is bent or its not pressing the switch to the point that the seat would not fully engage the safty switch.In some cases the switch itself is faulty.It has to be checked . Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
SOURCE: My lawn tractor with hydrostatic drive will not go in revese,
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
SOURCE: husqvarna lawn tractor will not drive
if it works in one direction but not the other its a linkage problem
On mine, which is a different model, it gets stuck like this when it is especially dirty. Start where the pedal is attached to the rod. I can see mine if I open the hood and look down. Make sure everything is free of debris and follow the rod all the way back to make sure everything is clear. Then do the same with the brake pedal. Works on mine every time!
