Probably will freeze as fridge settings get colder with the lower numbers
1 is close to freezing and 4 is probably where a fridge setting should be
sorry but I have to disagree here
fridge settings are as I state because the lower the number the greater the spring tension on the diaphragm on the thermostat so it takes longer for the thermostat to switch the compressor off so the colder it gets
freezer settings are as you state and you are right the setting for the fridge should be around the center numbers
Other way around Bill in MOST cases. 1 is warmest, 9 is coldest.
Most refrigerator temperature settings are controlled with a dial or slider. They are sometimes labeled 1 through 5 or 1 through 9. If you are not sure what to set it to, then set it somewhere in the middle. If the dial is numbered 1 to 5 set it on 3, if the dial is numbered 1 to 9, then set at 4. USUALLY the higher the number on the temp control dial, the colder the temperature your refrigerator will get. If your drinks and food are not as cold as you like, set the temperature dial up one number higher. If it is at 3 and you want your food colder, set it to 4 and test 12-24 hours later to see if your food is at the temperature you need.
http://removeandreplace.com/2015/03/04/r...
