Pool & Spa Logo
C
Carlton A Brooks Posted on Dec 16, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to repair a snowblower impeller that is stuck. No debris in sight.
NOEL
Level 3:
Top Expert:
  • Master 8,606 Answers
  • Posted on Dec 16, 2016
NOEL
Master
Level 3:
Top Expert:
Answers
8606
Questions
18
Helped
2318992
Points
68630
Craftsman snowblower carburetor-leaking gas,model#c950-52409-d,year 2004 briggs & stratton moter.
Possibly stuck carburetor float is stuck or debris in inlet needle valve or other.
How do I check if the gas line filter is clogged on the yardworks 31BM6BKE515 Snowblower?
Snowblowers typically dont have fuel filters. So of course the carburetor gets debris fouled and the repair shop puts in a inline filter.
The manufacturers dont like fuel filters for snowblowers because they can freeze if water is present. But I have a two strike rule. If a machine comes back more than once with debris in fuel, it gets a filter.
To check the filter (engine off and cool) disconnect the line on the carburetor side of the filter. Fuel should flow in a steady stream. If it drips, try a new filter.
If you have fuel up to the carburetor but no fuel in the cylinder (from carburetor) then likely the carburetor float is stuck. Especially if it sat for 10 months. You'll need to make sure fuel is filling the carburetor bowl. Loosen the carburetor bowl nut or remove nut and bowl. Fuel should flow steady from the inlet needle valve.
Nov 23, 2019 • Garden
Why will the impeller handle not stay locked down on my snowblower
this is the proper method of operation as you describe now , if it stuck down before then that was a miss operation and should have been repaired as that was an unsafe method of operation and not what the CSA and mfg intended im sure
your hands should never be able to leave the drive or augar control and it continue to run along as if you had the handles , this would make it far to easy for you to get your hands/feet into a moving part accdentaly and hurt you
Mar 05, 2015 • Garden
Rock stuck behind impeller on swisher snowblower model 627851xo7a how do I remove auger and impeller
if rock is quartz or grannite use a torch to heat them up and dose it with cool water , shatters the rock into sand happend all the time in the quarry i worked at on heavy equipment , that torch idea worked everytime
Swisher 27" snowblower front impellers turn free
Hi Craig,
Most snowblowers incorporate "shear pins" between the motor and auger. A shear pin looks similar to a nut and bolt or pin that couples the drive to the auger - but it designed to break or shear off to prevent damage to the auger or motor in the event of a jam or overload. They look like these:
Only the shear pin recommended for your particular brand and model snowblower should be used. Under no circumstances should a regular bolt or other steel pin be used instead of a shear pin. Check your manual or consult with Swisher to determine the correct shear pin for your snow blower.
I hope this helps & good luck!
Dec 21, 2012 • Garden
Low pressure in filter after pump 5-10psi
This would indicate a problem on the suction side of the system. Make sure all the baskets are empty and clean. Debris stuck in the impeller will also cause this problem. You may be able to reach the impeller and clear the debris without taking the pump apart. Just make sure the pump is not going to start running while you have your fingers near the impeller.
Hi, Wayne PC4 pump doesn't work. Can anyone help me?
The most common issue with these pumps is that the impeller gets stuck from non usage or from debris getting stuck in the impeller.
Take the cover off of the pump section and make sure that the impeller is free of debris and that it will turn freely. If it turns hard you may be able to free it by working it back and forth. This may take some time to do. I'm not sure about this particular pump, but on some you can get a lubricant like WD-40 worked into the pump and motor bearing also...
If the impeller is spinning frreely and the motor still does not turn on then you have a bad motor. To replace this motor will probably cost nearly the price of a new pump. It may be better to just replace the whole pump.
Heatman101
4helpful
Ariens snowblower impeller not throwing snow
Sounds like you have a broken or partially broken shear pin in the auger.Check along the auger[machine off]and see if there is what looks like a bolt anywhere along the auger shaft.If there is [and there will be] remove and inspect it and you will see why the auger is not working.Next time,never clean out a chute or auger while the engine is running,people loose limbs this way.
How can I keep my 2 stage snowblower in high?
I will assume you are referring to the 2 stages in the front of the machine. The spiral auger rakes are the first stage, they are designed to collect the snow and feed it to the impeller. The impeller is the 2nd stage and is to throw the snow up the chute. The lower rakes in the front do nopt throw snow only collect it.
Jan 09, 2010 • Mtd Garden
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
