SOURCE: Paper jam in HP 4255 office jet all in one printer
Clearing paper jams
Paper jams can be real or false. The unit may report a paper jam even when there is no jammed paper. The solution to a real paper jam or a false paper jam is the same.
CAUTION:
Jammed paper must be removed using the rear access door with the power cord disconnected to avoid mechanical damage. Do not remove jammed paper from the front of the unit.
Figure 2: Removing the rear access door
Preventing paper jams
The following information will help prevent paper jams from occurring:
SOURCE: paper jam
HI THERE,
try to turn off the unit & unplug the printer for
a while. check again for any stuck object/part or any debris inside the
printer.
let me know here again.
thank you
SOURCE: Paper in lower tray is not being "grabbed" by rollers to start the print or fax job.
I think you need to add some paper to it so that the printer will easily pick them,,,,or arrange the paper onto the tray..
SOURCE: I need an HP office jet 6210 paper tray
ebay.com type in HP Paper tray They are around 20 bucks and you could get it less then a week. hope this helps hun
SOURCE: In our office we have
From the P4015 manual --
1. In the software program, specify the source tray, the paper size, and the paper type.
2. Send the job to the product. If the tray needs to be configured, a prompt appears on the
control-panel display.
3.If the displayed size is not correct, press the back arrow the correct size, or highlight CUSTOM.
Press the down arrow to highlight
To specify a custom size, first press the down arrow to highlight the correct unit of measure.
Then set the X and Y dimensions by using the numeric keypad or by pressing the up arrow or
the down arrow .
4.If the displayed paper type is not correct, press the back arrow
to highlight the paper type.
Hope this helps.
