How do I open dismantle breville mixer Bem400
Undo two screws under the base which holds the entire top portion. The base and motor section should now separate. Remove the tilt lock from the tilt shaft, it needs to have two plastic tabs gently eased apart to slide off, there is one screw under here. There will now be three exposed philips screws on the underside with two more under plastic plugs nearer to the front of the mixer. Remove the two larger plugs to expose two more philips screws. These 5 screws hold the case together with a moulded clip at the front of the front of the mixer. ( Tip: a bead of hot glue on the plastic plug gives something to pull on with pliers, and not damage the plug)
