- Your telephone can accommodate up to four cordless handsets. You can add new handsets (Model E560-2, sold separately) at any time, but each must be registered with the base before use.
- The handset provided with your telephone is automatically registered as Handset 1.
- Additional handsets will be assigned numbers in the order they are registered (2, 3 or 4). You can register a maximum of four handsets.
To de-register all handsets• Unplug the power supply from the base unit.
• Remove all handsets from the charge cradles and base.
• Plug in the power supply while pressing and holding the HANDSET LOCATOR button.
• Continue pressing HANDSET LOCATOR until the IN USE and CHARGING indicators are lit (this could take up to 10 seconds).
• Release the HANDSET LOCATOR button.
• All handsets will display: ENTER BASE ID: XXXXXXXXXX
Once the base indicators turn off (up to 30 seconds), the handsets have been de-registered from the base, and can now be re-registered.
To re-register a handset:• Make sure your handset batteries are properly installed and charged.
• Your handset will display "ENTER BASE ID".
• Enter the 15-digit Base ID number from the bottom of the base unit.
• Press SELECT to accept the new code and complete re-registration.
To re-register a handset to a new base unit:• Make sure your handset batteries are properly installed and charged.
• Unplug the old base unit. Your handset will display "SEARCHING...".
• Install the new base unit by plugging it into an electrical outlet and phone jack.
• Press and hold the SELECT key until the handset displays "ENTER BASE ID".
• Enter the new 15-digit Base ID number from the bottom of the new base unit.
• Press SELECT to accept the new code and complete re-registration. The handset is now registered to the new base.
I’m happy to help further over the phone at
https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
same problem- AT&T wireless 2 line phone system 5.8 GHz
one handset gives message "T23 PD" occasionally. Doesn't occur with any of the other phones in the house
I'm sure it's not worth replacing the whole system (nor can I at this point- we've been using them all for more than 6 months).
Is it a battery/power failure issue??
any suggestions?
ativa phones all say searching
