My computer boots up but the LG monitor goes straight to "Analog Power Saving Mode". I have checked all cables rebooted. Have not opened in safe mode yet but gonna try that. Any other suggestions?
If you have a problem getting into safe mode using windows Vista or 7, boot up your computer. As soon as it tries to start windows turn off the power. When you try to start it again it should come up with a menu asking if you want to use safe mode or boot normally. Select safe mode.
Can you try the screen in another computer? I beleave the screen goes into power saveing mode when there is no input signal, thats what both my screens do.
LG does not show the 1750 monitor on their web site. It did show some discontinued monitors including a 1752, but there was no information available about them.
Another LG site said to use the far right bottom to auto adjust....for another monitor.
My HP has four buttons, MENU, <, >, and Return (also AUTO). Menu opens the monitor dialog box, with the arrow bottoms shifting through the menu. Select an item with return, then arrow to your selection, menu is also your exit button.
You may have a power saving selection here.
Also check the control panel for the POWER OPTIONS properties. A power scheme selection here will also change the mode of your monitor.
Mike sounds like the little bard in this monitor where the digital and analog connects to is in malfuction and can be purchased for $30 bucks on ebay. You tryed about everything I had on my list is why I come to this conclusion replacing this board will make the monitor work again if I where you I would investigate that.
i had the same problem.
connect the monitor with the analog cable and shut down your pc.
while it is off unplag the analog cable and place the digital one(dvi).
this should fix your problem m8 ;)
Fixing power problems with your LG Flatron Monitor (LG1753S) ... So after checking the power isproperly plugged, I shut down my pc again. .... I can start a game and then change the resolution, Popp of "energy saving mode digital" led goes ..
Right click on your desktop>Properties, then click on Screen saver tab, then at botton of the box you should see 'Monitor Power'.
Click on 'Power' then Power schemes tab.
Look at 'Turn off monitor' and set to 'Never'
