The front wheel bearing hub?
XL-7 (the dash matters)
my wild guess, is the questions was
what are all steps to do this job. and tools.
that?
RTM?
https://suzukipitstopplus.com/Products/10056-2002-grand-vitara-xl-7-service-manual.aspx
http://www.fixkick.com/hubs/FW_BEARINGS.html#newer
the link shows all years, and variances.
here is a photo review, that is accurate up to
1998, and beyond , if you skip the bearing service parts. as yours are INTEGRATED
and NON-serviceable.
the photo 6a and B
shows removing the hub,
so do that , buy a new hub and put it back
the same way, using the tool stated
at the stated ranges of torque
123-180 ft/lbs.
this range allows you to get the screws into the locking rings.
I sold all my suzuki dogs, when they went bankrupt here. (
and that very special tool ($80) that fits that silly non standard, axle hub ring.
(ie. GM truck tools do NOT FIT)
it's a ring nut, and needs this tool.
the bearings are crush type.
unlike say your boat trailer...
and if not set to the range of torque they will fail in under 3000miles says TIMKEN.
they have hard proof, (life tests and facts)
ring 19 is used, even on the newer cars,
with integrated hubs, too. (facts)
http://www.fixkick.com/hubs/4WD-89-91a.j...
the matching tool is here
here is that tool (NOT one sold in our brick auto stores, hard to find and buy them)
http://www.fixkick.com/hubs/FW_BEARINGS....
the torque is a range, as seen there.
and the locking rig tabs only fit some holes.
you can use the 2wd tool on the newer cars.
the removal is the same as the photo sequences here,
the only diff. is your hubs are fixed,
they do not come apart,
there are tiny 5mm screws that lock the ring
I have the official SUZUKI parts page on my
screen now, it has non servicable hubs
and has the same locking ring. seen above.
suzuki sells the hub with or without ABS
i had to buy a box of 5mm screws,
as the old ones strip out, on removal
they can.
after long long service, or water ingress
SOURCE: Torque specs on a 2006 chevy silverado front hub
The nut on the axelshaft is 177 ft. LBS.
The 4 bolts on the bearing hub is 133ft. LBS.
SOURCE: 2002 saturn vue. replacing front bearings. I
have you un bolted the strut and disconnected the ball joint you have to do this to have room for the shaft to come out
Testimonial: "One oclock in the morning, im still working on this POS and he answers my question. Does your mechanic answer the phone at 1 a.m.? Thanks!"
SOURCE: how to replace 2002 hyundai elantra hub and bearing
With the car on ground, break loose the drive-axle nut, and the wheel nuts , than jack up the car, support it properly, remove the wheel ,remove the axle-nut.
Remove the brake caliper assembly-- support it properly.
Remove the two bolts that hold the hub bracket to the Macpherson strut assemble, remove the lower arm ball joint and remove the steering tie- rod ball-joint attached to the hub bracket. That's it.Slide off the hub /with the bracket off the drive-shaft.
Follow steps backwards to assemble back.
SOURCE: Replace front hub assembly....
Replacing the front wheel bearing/hubs can be a big job for the inexperianced. Briefly...
Remove tire/wheel
Remove brake caliper assembly, do not remove brake line.
Remove caliper bracket.
Remove brake rotor.
Unplug ABS sensor.
Remove the large axle nut.
Press axle out of bearing (may need special tool)
Remove the 3 bearing bolts and remove bearing.
SOURCE: how to remove and replace front wheel hub assembly
Lift and SAFELY support the front of the vehicle.
Remove tire
Remove caliper bracket to steering knuckle bolts- larger and closer to the axle.
Use a wire or strap to support the caliper out of the way.
Remove the rotor
Remove the dust cap-( useless on these, but they put them there anyway)
Remove the axle nut- 36mm
Use a hammer and block of wood to make sure the axle is loose.
Remove the ABS wiring from the body
Remove the 3 15mm bolts from the back side of the knuckle.
Use the block of wood and hammer on the back of the hub flange to loosen the hub.
Remove hub
Clean the surface of rust,
Install new hub.
Here you can find the quality parts http://www.autopartspoint.com/products/wheel-hub-bearing.html
