Computers & Internet Logo
Somnath Laser Posted on Dec 09, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to recover windows 10, if MGR file is missing from recovery usb?
I have ACER laptop with windows 10, but it corrupted now, I try to reinstall windows 10 by recovery usb which i created. After 70% recovery automatic stopped, in recovery usb MGR file is missing, now what i do for reinstall genuine windows 10 ?
danoyachtcap
Level 3:
Top Expert:
  • Acer Master 2,907 Answers
  • Posted on Feb 22, 2018
danoyachtcap
Acer Master
Level 3:
Top Expert:
Answers
2907
Questions
Helped
1276049
Points
52081
Just go to "View Update History" and select "Recovery Options" then select "Reset This PC".
It's easy and will install, pretty quickly, a new Windows 10.
When that's completed, you should have a new Windows 10 installed.
dano
John Smith
Level 2:
Habit-Forming:
New Friend:
  • Expert 33 Answers
  • Posted on Dec 25, 2017
John Smith
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
33
Questions
65
Helped
18605
Points
155
Get in touch with us at Call Now 1-800-220-1032 Microsoft Windows 10 Support Number anytime to experience immediate answers for all types of Windows 10 issues. Our services are available for 24*7 hours available to assist customers in solving a wide number of issues as and when required.
How do i recover acer aspire one windows 7 starter with command prompts. Missing or corrupt NLS file
You can try the procedure at this link. Be advised that if it works, you will get the PC back, but you will have lost all personal data.
How to Reset the Acer Aspire One to Factory Settings
Acer E1 510 won't let me get into windows8 it says something about files missing or if I have a media installion USB or disk
Hi Courtney
It sounds like you have some corruption on your system. This could be due to an improper shutdown (forced shutdown without closing files properly) or a defective hard disk (these can go wrong from day 1 so be aware that 'I only just got the laptop' does not mean that the hard drive is not defective).
First and foremost, have you got any data (documents, spreadsheets, music, pictures, emails on the laptop. The reason for my asking this is before I suggest any course of action, we need to get your data off your system. Now to get your data off (assuming you don't have the files in an intact backup file - either full or incremental) the try this link and follow the appropriate instructions
Recover files from corrupted hard drive with best data recovery software
Once you are happy that you have the data safe, I assume that your system is no longer in warranty (if so check with Acer to see if they can help) and that you do not have the recovery media created for your laptop. There may be an option to enter Recovery mode during the startup sequence, please look at the bottom of the screen while the laptop starts up. It will be before the laptop attempts to load windows. Hit the appropriate key, this is usually a function key such as f12, or f4 or similar. From here follow the laptop makers instructions to recover the system. A word of warning This Will COMPLETELY clear your harddrive and put a new copy of the operating system (windows 8/ 8.1) on the system. No DATA will be saved. Other than this the system needs to have recovery files, which may be available via Acer or alternatively look online for sites which make recovery files available at a cost.
This is a link to a copy of the manual, which you should have, but in case you don't
Acer Aspire E1 510 User Manual Windows 8 1
I hope this helps
Regards
Hayden Williams
Green Dragon Solutions
www.gds888.com
4answers
\windows\system32\winload.exe missing or corrupt 0xc000000f
":\windows\system32\winload.exe " Status: 0xc000000f This error message states a missing or corrupt Winload.exe file, due to which the booting process of the system halts and the data stored in the hard drive becomes inaccessible. Cause: Following are the causes for the corruption in Winload.exe: Software or hardware issues. Corrupt Boot Configuration Data (BCD). Incompatible partition. Resolution: To resolve the above issue, consider the measures below: To fix the corrupted Winload.exe file, use the Windows Recovery Environment. To do so, use the Startup Repair option in the System Recovery Options dialogue box and choose the operating system to repair. Using the Windows Recovery Environment will restore the system to a particular point, which will get the system to an appropriate working state. In most cases, the above measures will help you to resolve the issues related to Winload.exe. But, if the problem persists, then you will need re-install Windows. But, a clean re-install of the Windows operating system deletes all the data stored. In these situations, to recover your data completely, it isrecommended to use a high quality Windows Data Recovery Software. The Windows Data Recovery application incorporate advanced scanning algorithms to ensure quick and comprehensive recovery of your data. Stellar Phoenix Windows Data Recovery v4.1 is the most appropriate utility that recovers your lost, deleted or inaccessible data accurately. The Windows Data Recoveryapplication offers highly intuitive graphical user interface, that makes it easy to use and understand without any prior technical understanding. This recovery tool is fully competent to recover data from FAT16, FAT32, VFAT, NTFS and NTFS5 file system based disks. The read-only software is compatible with Windows 7 RCI, Vista, XP, 2003 and 2000.
My Acer aspire is still saying boot mgr is missing after I put in the system recover disc what do I do now?
To repair missing or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
My acer laptop says windows error recovery I plug in my phone to my laptop it says windows failed to start a recent hardware or software change might be the cause
Windows is severely corrupted - critical files are missing. Recover your personal files while you still can and reinstall everything from the beginning.
3helpful
3answers
Please help! Acer Aspire one, mod No ZG5, will not start windows. Missing or corrupt: <Windows root>\system 32\hal.dll. Please reinstall a copy of the above file. But it came with no disk ???
You need to reinstall windows, I think. You can also try to use yhe Recovery console to recover the selected file ( in your case hal.dll). But for that you have to get the windows installation cd/dvd first.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
