SOURCE: colored vertical lines with sound no picture
im afraid to say that your display has gone the best thing you can do is call the supplyer of the tv if its under warranty or call samsung. the cost of a new display will be 400 - 500 pounds so you may have to buy a new set.
SOURCE: vertical lines on screen
Be sure the TV has no problem by playing a DVD player. If problem remains unchanged, call for service because a few boards could involve to. In the worse case, panel should be defective.
SOURCE: colorful vertical lines on screen
more likely to be bad LCD panel (very expensive), but you can try replacing the LCD controller first (around $80~100).
SOURCE: Colored "snow" vertical line an inch thick on Samsung plasma
That is the sustain and buffer boards. Try to find a repair shop to repair on the component/board level because the cost of new boards out weighs the replacement cost.
Best Regards,
Beach TV Repair
SOURCE: Have a Samsung LNS4041DX.
Defective panel, or bad ribbon cable that is associated with the color lines. ribbon cables are at the bottom, or th sides and will be in line with the color lines on the panel remove cables clean and reinstall.
