None of those seemed to address the rattling you described. Our Sante Fe started doing that after sitting all summer. It operates fine, but when the auger is not feeding it makes a rattling noise that appears to come from the auger motor area. When the auger is feeding or you lift the fill lid it stops vibrating. Still trying to figure this out.
SOURCE: I have a Quadra fire 1200 pellet stove insert. The
It may be working properly. If it seems that it's a little cool in the room and the blower is cycling like you say then the stove may be getting chilled. If this is the case then the low-temp switch is cutting the blower off.
If the room is quite hot there may be a problem with the blower. Check to see if it has a bunch of dust in it making it run hot and tripping the internal thermostat.
Please respond with the 'comment' button, down below the ads. I'm considering a pellet stove and I'd like to hear anything you have to say about yours.
lp
SOURCE: My St. Croix Hastings pellet
Check for power to the auger motor... power but no run equals bad motor and/or jammed auger... no power means bad board or high limit cutout needs reset...
You will need to do some checking and try ti figure out what is going on....
From the mention of the squeaking I would say that maybe a bearing went out on the auger and siezed up which may have also burnt out the motor...
heatman101
SOURCE: Quadra-Fire Pellet stove-Pellet pot fills.
Sounds lie an Ignition Box problem. Quadra Fire recently redesigned their Ignition Boxes, so your may wan to replace yours. In addition, contact Quadra Fire Technical Service and speak to Steve Tate. He's a real guru when it comes to this problem. Don't settle for anyone else.
Hope this helps solve your problem.
Testimonial: "Thank you...don't know who Steve Tate is but will definitely look into Ignition Box replacement."
SOURCE: quadra fire pellet stove will
min firepot - do a neg 3 to neg 5 flame/height try running on auto
try mixing with a small amt of wheat - set to utility setting (regardless of premium brands)
pull thermocouple off and put back on - might need a new one but the upgraded firepot that comes with a new element might be all that's needed as an upgrade
Reasons to upgrade: The upgrade to the bottom of the pot to the element is much bigger. There is also a large opening at the bottom of the element mount to aide in air flow upward to the pellets
Upgrading the firepot that comes with a new element - be careful of the TC Sensor cable - use plenty PB Blaster (wd-40? White lightning?) - slowly rock bolts back and forth - don't break the bolts!
Remove old cover around TC sensor and replace with a new TC Sensor ceramic cover from Preston Trading Post - might help
If the thermocouple is heated and produces millivolts, it's good. If it has continuity it is good. - make sure conections are pushed inside well enough on the pins.
You can test the board. Unplug stove. Then pull the firepot T-couple connector off the board, making sure which direction it sat. Then install a jumper wire on the exposed pins. Make sure it is clips with plastic covers that won't ground out. After installing the jumper wire, plug the stove in and check the wall control. If the error code for the firepot t-couple goes away, the control board is good. If the code pops up again, the board is bad.
jump the thermocouple connector pins on the control board, plug the stove back in -should be no error codes - tweaking the pins on the control board for a better connection - sometimes works
Also visit iburncorn.com
