Televison & Video Logo
Norbert Pierre Posted on Nov 30, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vizio 2 year old p702ui-b3, comes on with vizio emblem, emblem goes out menu comes up, as we start setup, set dies, light at lower right shines and goes out at same time screen goes out.
Set stopped working, only lower right corner lite comes on, goes off, nothing works. Replaced power supply board, no change, replaced main bd, does what it does now, only on for a few seconds. No blue screen at any time, menue block looks good, bright etc
Tony Curto
Level 2:
Sergeant:
  • Expert 246 Answers
  • Posted on Dec 01, 2016
Tony Curto
Expert
Level 2:
Sergeant:
Answers
246
Questions
Helped
49640
Points
675
Check to see if in demo mode
1helpful
Vizio P602ui-b3 LED TV that had a half screen of static and now won't turn on
See if you have 24 volts from the power board that feeds the LED driver board to start with
Vizio p702ui-b3 power board t-con voltage reading do not match what printed on power board
According to the service manual on your set you should see 12 volts on the power fuse on the tcon board...what do you have
1helpful
How do I replace the LED driver on a Vizio P702ui-b3?
Its part of the power board but are you sure that's the problem, more times than not its bad lamps not the LED driver bad.
What component or components need to be replaced to fix the tv?
Try replacing the inverter board which powers the backlights on set.
1helpful
My TV has 4" of blank space on the right and the left of the picture. My TV is a 4 year old Vizio. Is this an indicator of a TV dying?
Might want to check if the aspect ratio in the video setup got messed up. (Should be 16:9 or auto.) Also check that you're watching a HD channel or a HD DVD. Your cable box may have a video out setting that got reset incorrectly.
1helpful
For about a month when I press my vizio on switch the tv would click on the vizio emblem would light up,then it would immediately click off and the emblem would go dark...I would have to repeat this...
unplug the TV. Press and hold the power button for 30 seconds, repeat. Plug it back in and try again.
More troubleshooting can be found at www.vizio.com
70helpful
10answers
I'm trying to register my new vizio television
Just go to www.vizio.com. On the choices at the top pick "register". It's that easy. I just did it.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
