Question about Canon A2200 Digital Camera
Camera battery insertion instructions for TC-55C charger. battery model # NB-8L and is for a Canon A2200
  • Canon Master
  • 6,132 Answers
This information will be in the camera manual.
Posted on Nov 30, 2016
6ya staff
SOURCE:
Tip
Digital camera battery, camcorder battery and charger online store -...
Laptop batteries, like all rechargeable battery packs, lose their charging capacity over time. Because new Laptop batteries are expensive, replacing the individual cells inside the battery casing can save a lot of money. However, rebuilding a battery sometimes does not work as expected, so it’s important to be willing to purchase a new laptop battery if the procedure fails.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250
HP Pavilion DV1100 Battery 12 cells
1、Allow the laptop battery to run down completely. Turn off your laptop, then remove the battery. Write down the model number located on your battery to help identify the type of Li-ion replacement cells you need to purchase.
2、Split open a small section of the laptop battery pack (at the seam) with a screwdriver or craft knife. Continue to pry the plastic case loose moving around the outer edge until the entire top is free. This may take a bit of force.
3、Note the number of cells inside the case (usually four to eight). Write down the part number and voltage information printed on the cell casings. Draw a diagram showing the arrangement of the cells and how they are connected, or take a few photos to help with reassembly.
4、Purchase the correct number and type replacement batteries from online shop such as udtek.com, based on your battery model and cell specifications. Six Li-ion cells typically cost around $30 to $40.
5、Carefully remove each cell using a craft knife and wire cutters as necessary. Each battery pack is different, but the cells are usually wrapped in a plastic casing with metal contacts attached to one end. Lay the metal contacts, wires and casing material aside.
6、Use double-sided tape or a solder gun (only if necessary) to attach the metal contacts to the cells and circuit board. When finished, the old cells should be completely stripped (naked) and the new cells should look like the old ones as much as possible.
7、Place the new cells inside the case, referring to your diagram or photos if necessary. Glue the battery(Compaq DV6000 Battery) pack top back on. Charge the new battery for at least 24 hours before using it.
Tips & Warnings
Keep an eye on the new battery while it charges for the first time. If the contacts are not connected properly, the battery could overheat and cause damage to the laptop.
on Oct 21, 2010 | Computers & Internet
It's not charging my camera battery
Your camera battery is faulty,you must replace the battery with the new one
Mar 31, 2013 | Digipower TC-55C compact intelli-charge...
I have A2200 cannon powershot camera but the flash is not working
You can Google your camera make/model and open the link to download your user manual in a PDF. I did this and picked the one below. Under the Table of Contents, pick Turning off the flash. The instructions to turn it on are there as well.
Hope this helps. Mike
CANON POWERSHOT A2200 USER MANUAL Pdf Download. www.manualslib.com > ... > Digital Camera > PowerShot A2200
View and Download Canon PowerShot A2200 user manual online. PowerShot A2200 Digital Camera. PowerShot A2200 Digital Camera pdf manual download.
Dec 16, 2012 | Cannon Cameras
How do you recharge the battery on the power shot sd 1100?
A quick look on Cnet reviews says the specs for battery and power are:
Power
  • Power Device Battery charger - External
Battery
  • Supported Battery Canon NB-4L
  • Supported Battery 1 x Canon NB-4L Li-ion rechargeable battery ( Included )
An NB-4L battery charger is what you need to charge the battery for that model. My Canon charger is a small box with fold out wall socket prongs and a mount for my battery to slip into.
This looks like a Generic version sold on eBay, that includs a Euro/mexico Socket adapter.
Dec 11, 2009 | Canon PowerShot SD1100 IS Digital Camera
Instruction manual
Your specific manual is here.
You can find Sanyo UK owner's manuals here
Sep 13, 2008 | Microwave Ovens
Lost charger
No you can't. Recommend just buying another charger. Generic NB-4L chargers are relatively inexpensive ($6 to $10). So are the generic NB-4L batteries. Here's some chargers from Amazon:
http://www.amazon.com/s/ref=sr_st?keywords=canon+nb-4l+charger&rs=172282&page=1&rh=n%3A172282%2Ck%3Acanon+nb-4l+charger&sort=price
Feb 16, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon A2200 Digital Camera Logo
149 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
