SOURCE: Kneading Blade Stuck on Kenwood Mixer KM300
Lightly tap out the dough with a piece of wood in the direction you would usualy remove it
SOURCE: How do I remove and refit a motor to my KM300?
What you need is a service manual which is difficult to get for any Chef regardless of the KM300. Ive got a KM310 model but the user manual is similar to this if it helps:
http://www.kenwoodworld.com/datasheets/KM336--KW89421iss2%20KM330-KM630%20%20English%20-0.pdf
SOURCE: KitchenAid 600, Stand Mixer -
Hi. Stop using your mixer. If your mixer is still covered by warranty, call Kitchenaid Customer Service, they are very good with warranty repairs.
If your mixer is out of warranty, remove the silver band that surrounds the top of mixer. Remove the top cover. At the front of the mixer, locate the transmission housing which is now exposed. Examine this housing carefully for cracks. If you find cracks anywhere in this housing, you have found the under-engineered plastic transmission housing. Kitchenaid's replacement housing is made of metal. Your plastic housing has no business being in a mixer that is marketed as being able to mix bread dough. It cannot!
If you're confident that you can make the repairs yourself, go to the Kitchenaid website and download the parts drawings. Remove the Trans. housing, remove the worm gear shaft assembly which is driven by the motor.. Remove and save as much grease as necessary to thoroughly inspect the worm gear. Inspect the worm shaft bearings. Look for cracks, or missing pieces on the bearings. Look for crunched cogs on all gears. Be prepared to wait at least a month for your parts to arrive after you order them. The replacement grease should be Shell Darina 2, or Chevron FM ALC EP 2.
If you're not confident about repairing this yourself, call Kitchenaid and determine the nearest "approved" repair shop.
You may be able to pressure Kitchenaid to pay for the damaged parts in your mixer. They are still installing these plastic Trans. housing on new mixers. Insist on a metal cover when replacing. Apparently, Kitchenaid feels no shame in their manufacturing process, and will not issue a recall notice for these housings. They are substandard at best.
If you found this solution helpful, please rate it. Good luck! ricardok45.
SOURCE: I was making bred dough with the mixer and when
You have broken the intermediate gear in the head. This gear can be a bit of a problem to change. Here is the parts manual for the KSM150PS.
The part is probably #6, worm gear.
Check with Kitchenaid on where to buy parts.
SOURCE: Looking for a dough hook and bowl for a blakeslee
Blakeslee is still around phone # 1-708-656-0660
