Then it will build up again and won't dispense. There are no controls inside the freezer to make adjustments.
Suggest turning the ice maker off by elevating the shutoff lever arm. If ice continues to build after a few days the solenoid water valve is leaking and needs to be replaced.
If no ice build up it is likely that the fill tube is dirty and water is freezing in the tube disrupting the normal tray fill process.
Hope this helps?
