Vacuums Logo
T
Tina Tinsley Posted on Nov 28, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Dyson V6 Slim about a year old. It's stopping and starting - not continuous power. I have cleaned the brush the canister and the filter and it's still not working right. Help!!!!
Think Crucial
Level 3:
Master:
  • Dyson Master 894 Answers
  • Posted on Nov 30, 2016
Think Crucial
Dyson Master
Level 3:
Master:
Answers
894
Questions
0
Helped
711209
Points
8395
Hello, this is Ava with Think Crucial.
There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it maybe due to a battery of the unit. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson+v6
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Dyson dc17 clogging hose near brush, no dirt going into cyclone canister.
all battery vacs work on the same principle
so you have to clean out the hose behind the brush right up to the canister.
Hoover air stick has the same problem so they changed the head so that a removable section can be taken out the hose pulled up and a bottle brush can be used to clean out the hose to the canister and behind the brush
You will have to clean out behind the brush up to the canister to fix the problem
My Dyson V6 absolute is pulsating when I pull the trigger. I have cleaned the canister and checked for obstructions. I also cleaned the top filter.
Ava B.
Dyson V6 animal powerhead starts and stops does not run continuously
There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it maybe due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
Ava B.
Brush head will not spin. Canister is completely clean yet no rotation to be seen.
If cleaning the brush bar really well doesn't solve it you may want to replace the filters. If that doesn't work you may need to replace the brush head.
Dyson DC23 canister vacuum turbine head attachment stops spinning.
bearing inside the turbine has failed. cant be repaired you will need to buy a new one your local vac centre will have one
2answers
Dc 39 canister carpet brush will not turn
on the head there is a round filter type part if that is pushed in the the brushes won't turn. try pulling it out slightly.
The main brush head on my Dyson Digital Slim will stop turning during vacuuming. I let out on the power trigger, push back in and the brush head will work for a bit and then stop again. My digital slim is...
It's probably due to a build-up of dirt/hair around the brush head or a blockage in the suction head just behind the brush (where the hole is smaller and bends slightly before entering the extension tube. Remove the brush from the head of the machine and also the extension tube between the head and the top of the machine and then gently clear the rectangular hole in the brush compartment with something flexible (maybe a piece of wire or a pipe-cleaner) depending on how bad the blockage is. Then remove any hair/strands which may be wrapped around the brush, and any dust in the brush compartment. It may also be a opportune time to wash out the filter which is located just in front of the handle on the upper part of the machine. Leave the filter to dry completely before refitting (in an airing cupboard or near a radiator - may take some hours)
My dyson dc08 has no suction when i put the canister back on, however i can feel the suction without the canister on. why is this doing it and do i need to replace this unit. I have thouroghly cleaned the...
It sounds like the motor is functioning properly and the filters are fine. Check very thoroughly for clogs in the parts after the canister (down where the brush is, etc.)
2helpful
Dyson power head stops when on carpets, cleaned brush out, still happens.
Hi its Darran at Dyson.
As the Turbine head is air driven, you may need to wash the filter and check the rest of the machine for a blockage as a loss of suction will also reduce the performance of the Turbine head.
For the full blockage procedure and filter washing instructions, please visit the Support section of our website at www.dyson.com.
Kind regards
Darran
Dyson Customer Service
12helpful
Cleaning filter on the Dyson Slim
You don't have to clean the HEPA filter (underneath the canister in that clear part) - if you break that clear part you will cause damage to the machine and it won't **** anymore as the air will escape. There is no need to remove it or replace it, it is a lifetime filter. You only have to clean the blue filter that is inside the top of the canister/dirt bin.
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
