Car Audio & Video Logo
Bobby Lansford Posted on Nov 28, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Looking for bass/treble adjustment on mx2800. does it have one?
Jerry Kramer
Level 3:
  • Master 3,933 Answers
  • Posted on Nov 28, 2016
Jerry Kramer
Master
Level 3:
Answers
3933
Questions
Helped
882091
Points
12076
It is most likely on your volume button. Depress it once and it should switch to Bass....press again and you should see treble, clock adjust..etc. Use the volume knob to adjust
I need to adjust bass and treble on the 65uk 7500 model
  1. Turn on your LG 65UK7500 TV and ensure it is connected to a video source.
  2. Press the "Settings" button on your TV remote. It is usually represented by a gear or cog icon.
  3. Use the arrow buttons on the remote to navigate to the "Sound" or "Audio" settings. Press the "OK" or "Enter" button to access the sound settings.
  4. In the sound settings menu, you should find options for adjusting various sound parameters, including bass and treble. Look for options like "Equalizer," "Audio Settings," or "Sound Mode."
  5. Select the option that allows you to adjust the bass and treble settings. It may be labeled as "Bass" or "Treble."
  6. Use the arrow buttons on the remote to increase or decrease the levels of bass and treble according to your preference. Some TVs may use numerical values, while others use a graphical representation.
  7. Once you have adjusted the bass and treble settings to your liking, press the "OK" or "Enter" button to save the changes.
Is the base and treble audio adjustible on this 1996 Sony TV KV- 20S20
Adjusting various sound settings (e.g. bass/treble ... - Sony
docs.esupport.sony.com/imanual/NA/EN/hx850/c_snd_qv.html
You can adjust various sound settings, such as bass, treble, balance, etc. ... [Setting Memory]: Applies custom sound settings to the current input or to common ...
General information on how to adjust the bass and ... - SONY
https://us.en.kb.sony.com/.../general-information-on-how-to-adjust-the-b...
Aug 15, 2015 - Follow this procedure to adjust the bass and treble surround parameters on the A/V ... Adjustable sound field parameters vary by sound field.
1helpful
How to adjust bass and treble and surround sound
On the Remote Control
Press
1 TONE
ToneControl•OFF-
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
NOTE
The tone cannot be adjusted in the direct
mode.
3 Press
to select an item to be set, and use
TONE
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
"ON
2answers
Thanks for the answer - If we have 3 controls as Bass, Mid and Treble. If we keep those in 12 O Clock position, will the output level be equal. In using the Bass and Treble control only (if we have...
If all are in 12 o'clock position they are "flat" (nothing has been added or subtracted foam input signal) If you only have bass & treble, yes adjusting will affect "mids" but Mids change can go both ways dependent on increase or decrease of Bass and /or treble. By increasing bass you will pull some mids up also. By increasing treble you'll subtract some mids.
How come when i push the "A-M" button to use my sound controls all i get is the balance and the fader? no bass and no treble
You can only use bass and treble if your Z-Enhancer is OFF. If it is on excite or bass boost you cannot adjust bass or treble
2helpful
Can't adjust bass and treble
The only adjustments available on the unit are Volume and Bass (Subwoofer Level). There are no Mid-Bass or Treble adjustments.
Having Trouble Assessing Bass and Treble Controls
Bass and treble can be adjusted via the sound menu only when the z-enhancer is set to off.
To change them while the Z-enhancer is on (B-Boost, Excite, Impact) choose the enhancer mode, then press the play/ent button. You can then use the up/down arrows to adjust bass and treble to -3 to +3
How the heck do I adjust the radio sounds (Bass/Treble)??
in newer sound systems they usually have an button that says audio with push of the button it should give you options of adjusting balance fade bass treble etc.
New car, no manual
There is no straigt forward bass and treble adjustment. You must adjust in either the (x-over) or (users EQ) function. It is a bit tedious but performs the bass and treble adjustments at multiple frequencies.
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
