Singer 3116 Simple Logo
Teresa Webster Posted on Nov 27, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 3116 singer simple stuch in reverse what can i do to fix it?
matty_w
Level 2:
Legend:
An expert who has written 200 answers of more than 400 characters.
  • Singer Expert 631 Answers
  • Posted on Dec 28, 2016
matty_w
Singer Expert
Level 2:
Legend:
Answers
631
Questions
0
Helped
183088
Points
809
What happens if you PUT it in reverse -- does it sew forward?
5 Related Answers
Anonymous
  • Posted on Nov 05, 2008
SOURCE: SINGER SIMPLE 3116
Cope and paste the following link into your web browser. You can order a hard copy of the manual or download a free copy onto your computer.
http://www.singerco.com/accessories/manuals.html?man_model_no=3116
Hope this helps! :o)
ken dourof
  • 980 Answers
  • Posted on Nov 04, 2009
SOURCE: top part of singer 3116 is squeaky
Oil the top of the needle bar very lightly and the moving parts of the takeup lever, if you still have it then I would suggect taking it in for a check before it costs a lot of money
Testimonial: "Thank you Thank you Thank you!!!"
Anonymous
  • 59 Answers
  • Posted on Mar 30, 2010
SOURCE: where do i oil im got a singer simple 3116
your machine is not self oiling machine. you only put some oil on the needle bar.and under the presser foot
Anonymous
  • 1788 Answers
  • Posted on Sep 09, 2010
SOURCE: Singer Simple 3116, tension way to tight even when
Call Singer at 1-800-4singer customer service, if you play with the tension and don't know what you are doing, you can mess it up big time. Watch the dvd that came with your machine and read the manual
Anonymous
  • 340 Answers
  • Posted on Sep 22, 2010
SOURCE: i cant thread my singer
Do you have a manual?
You can download a manual from the Singer site for free.
Just type in 3116 and click on search.
On the next page click on the free download option.
Hope this helps!
Installing reverse lever for Singer Simple 3116
How To Reverse Stitch On A Singer Sewing Machine Correctly
Step 1. Press the reverse button
  • Refer to the Singer manual of the specific machine you have
  • Please find the button with the U-shaped arrow, typically at the front of the sewing machine, or check your manual for where it's located
  • Press the reverse stitch button and start sewing
Step 2. Start sewing
  • Hold the material as the sewing machine sews backward and stop it manually by taking your foot off the pedal
  • Deactivate the reverse stitch function by pressing the button again
  • Be careful not to hit the thread plate to avoid bunching
  • If you accidentally press the wrong button, turn off the Singer sewing machine and turn it on again to reset
My Singer 3116 sewing machine will not sew. I try to turn the wheel and it will not go the right way but will go like in reverse.
if the machine is turning it will sew
what may be your problem is that the sewing direction is in the reverse stitch position
if that is not the case , take it in to a sewing machine repair shop for a proper diagnosis
2answers
Where can I find a power cord for singer simple 3116 sewing machine?
It looks like your power cord and foot pedal are incorporated into one unit, and you'll have to replace the foot pedal to get it. You can get it for $30 at sewing parts online, http://www.sewingpartsonline.com/singer-3116-simple-sewing-machine-parts.aspx?gclid=CLTXmrLC18ECFeHm7AodBioADg, and you can also get them from eBay by doing a search on Singer Simple 3116.
1helpful
Singer 3116 simple out of line
well you can take the machine to a sewing machine shop & have it serviced or try do the retiming yourself
youtube
fixsewingmachine.com
sewusa.com
Sewing in reverse
Take it to a repair shop for assessment, you will not get into it...got a warantee ??
Reverse Lever isn't working...
Most likely the "dogs" inside the lever are broken off. Oil/grease on the metal rod cause chemical attack to the plastic lever and the "dogs" break. Singer should know to degrease this rod before assembly.
Singer simple 3116 will not reverse
Sounds like spring or something disconnected from the lever. Take it in to your dealer or look at yourself carefully.
Singer 3116 won't go into reverse
here is a download for your manual
http://safemanuals.com/user-guide-instructions-owner-manual/SINGER/3116-_M
pg 32 talks about sewing in reverse sewing.
but doesn't give much on trouble shooting other than hold the lever while sewing. If that's not the case, then I think your feed dogs are the issue. check your feed dog drop. pg 9 part 12
If you think the reverse lever is sloppy, professional action should be taken, (take it in to be repaired under warranty?)
I hope this was helpful.
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
