Toshiba REGZA 42RV530U 42 in. LCD HDTV Logo
L
Lora Skinner Posted on Nov 25, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What size screws are used to attach Toshiba 42RV530U to the pedestal stand provided?
Level 3:
Top Expert:
  • Toshiba Master 76,851 Answers
  • Posted on Nov 26, 2016
Toshiba Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14995373
Points
237762
Mild steel screws 4/3 inch in diameter.
How do I remove the pedestal from the 42RV530U?
1.) Set the t.v. face down on a flat, but soft or cushioned surface as not to damage the screen. As you face it down, remember to position the t.v. so the stand is sticking out over the edge of the surface you are placing it on.
2.) There should be four screws on the back of the t.v. set near the stand. Remove them.
3.) Once you remove the four screws, you should be able to pull the pedestal stand away from the t.v. set by sliding it out of its holder.
Hope this helps!
1helpful
Toshiba 40rv5252r stand screw size
I called Toshiba for this TV model "40RV525R" and they said the pedestal stand for the t.v. to stand on was an m5, product # 75012791, and the length was approx 20-25 mm
1helpful
I need to remove the stand from my Toshiba 37HL67 so I can mount it on the wall. Can you help me. Auburn [email protected]
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface.
Note:
Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand a way from the TV (Remorve 5, 4mm or 5/32" Allen Bolts from back of TV.)
For Mordels
26HL67
32HL67
32HL67U
37HL67 = My TV
42HL67
Herb
28helpful
2answers
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Note: Extreme care should always be used when removing
without tools.
3) Remove the four screws shown in the diagram below. This will
4) Once you have removed all four screws holding the pedestal
sliding the pedestal stand away from the TV.
3helpful
Can't remove the base/feet - i want to mount on the wall. if there are screws, we can't find them - tried allen wrench, phillips, etc., no luck. thank you
See page 5 of the owner manual:
without tools.
http://www.tacp.toshiba.com/tacpassets-images/models/47HL167/docs/47HL167_om_e.pdf
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
5helpful
I need a pedestal stand for my Toshiba 42RV530U. Do you know where I can get one?
Manufacturer Toshiba Part Number 75010935 Description BASE BASE ASSY, BASE
Can't remove base from Regza 37HL17
download manual and check' page 5 'for wall mounting.
without tools.
Five screws
6helpful
I want to remove stand from 42 to hang on the wall 1080
Click here to download the user's guide and check page # 5 for instructions on how to remove the pedestal stand.
4helpful
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
