SOURCE: lifting the top to clean spills
Hi
Look under the counter top find the bolts that secures the stove top, unplug the power and remove the top, then look around the edges of the stove top and you should see some small screws that atach the glass to the frame, remove those and lift the glass carefuly, "DO YOUR THING" and then just reverse the steps and done.
Eddie Rentas
Tupper Lake NY
SOURCE: Over the Range Microwave Oven
my microwave oven have inside a a metal papel i remove becouse sparks when turn on .this pece of paper is necesari
thanks
alexas
SOURCE: oven does not heat up
I had the same problem with my magic cheff oven. I had to set the temp at 400 - 500 degrees to get to get an actual oven temp of about 250 degrees. The oven temp sensor checked ok with an ohm meter. Should be around 1100 ohms at room temp. I work in the electronics industry and know capacitors go out of range and dry out with heat and over time so I replaced the 3 or 4 electrolitic capacitors on the timer board. Cost me about $6.00 at Radio Shack and now my oven temp is right on the money. I realize not everyone may want to do this but it worked for me. Better than the $200.00 for a new oven timer control board. I have also found a company's website that fixes these boards for about $89.00 ApplianceTimers.com
SOURCE: schott ceran stove top from Sears, all burners are
Check here...
http://www.schottceran.com/
Also try and find a product called "KickIT" of get it here.
http://www.muleheadbrand.com/pdf/degrease-it-etc--web.pdf
This is an industrial degreaser I used at work. Be careful with it as it will peel paint! But is does a great job cleaning the oven top. Spray, let it set a few and spray again. You may still need the scraper, but it will come clean much easier.
Added TIP: Got one of those reusable filters in your window AC unit?
Take it outside and spray it down with this full strength. Hose it off when you are done and it will look like new. I also use it to clean smoke residue and crud off of computers (caeses) for a fairly new look.
SOURCE: ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
